Newbie csjohsn3
4 Channel ADC 200ksps FPGA
Im am working on designing a FPGA board that can process 4 signals at a time. I essentially need to be able to do have 4 ADC channels and be able to do 4 FFTs simultaneously. Is there a dev board that would give me this capability? Or am I better off to get an FPGA dev board and design my ADC input circuit seperately?
Advisor joelby
Advisor
Re: 4 Channel ADC 200ksps FPGA
Nothing comes to mind, but you're usually better off designing an ADC board to your own specifications - you haven't mentioned ADC precision, input voltage range, etc. and generally a dev board won't do exactly what you want. You could check if Digilent have a module that does something similar though.. I know they have some ADCs, but I'm not sure about four channel ones.
Teacher muzaffer
There are several quad ADC FMC boards. Search for "4 ADC FMC" with any search engine and you should get several results.
