AC701 PCI issue?
I have a dev board I recieved  recently, im testing inside a desktop PC on win10, I have the 6pin to 4 pin molex for power on the board with the power switched on, the board lights up but the board doesnt seem to be recognized by the operating system in device manager after booting into the opeating system. any steps I might need to try or be overlooking?
Hi @illwill ,
Answered through SR.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Advisor
Advisor
@illwill I haven't used the AC701, but I think you need to put a PCIe design on the chip before it'll talk to the PC. The AC701 Targeted Reference Design looks like a good candidate.
Do you have a link for the reference one?
you can get it from here (the second item from the top) https://www.xilinx.com/products/boards-and-kits/ek-a7-ac701-g.html#documentation
currently dont have a test pc to use anymore so using original pci adapters to connect to mini pci-e inside laptop that i was usuing originally, these worked to read data originally but dont work anymore, ended up buying new adapters just in case they were a failure point but still not able to talk to the pci-e, thining maybe an issue on the board itself. but have no idea how to test if theres any life in the connection because im using code form someone elses project
AC701 does not take power from the PCIe slot. If you are using a laptop to host the AC701, you will need to find an external power source for the six pin power connector. Once powered, check the leds for voltages and heart beat if the code drives a led for heart beat.
The best way to test the board is to follow the AC701 Targeted Reference Design User Guide https://www.xilinx.com/support/documentation/boards_and_kits/ac701/2015_1/ug964-ac701-trd-ug.pdf and see you get the same outputs.
Hello @illwill ,
Is there any further assistance required in relation to this matter? If so, please let us know and we will be glad to help you further then.
However if your query is answered now, please mark a response as 'Accepted Solution' (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
waiting for tech support to get back from holiday to assist with testing
Hi @illwill ,
Deepak D N
