Bare Metal M_AXI_HPM1_FPD Bus access failure on Zync UltraScale +
Using the ZCU111, I was trying to access memory on the PL side from the M_AXI_HPM1_FPD bus, but was unable to do so using a Baremetal solution.  However, reading and writing from the M_AXI_HPM0_FPD bus was successful.  I used the following instructions to setup the Ultrascale to access memory on both buses:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/66551810/Creating+FSBL+PMUFW+from+XSCT+2018.3+for+ZCU111+and+boot+over+JTAG
Is there additional to the instructions in order to get HPM1 to access memory on the PL-side?
Edwin
Tags (2)
