Observer wave85
Boot from QSPI Flash on ZC706
Hi all,
i've read many forums and discussions but i haven't figured it out yet.
I clicked on Create Boot Image, created a new .bif file and added the FSBL, bitstream and application.
Then i created the image .mcs and programmed it into the flash.
Afterwards i change the switch SW 11 to 00010 to enable the boot from QSPI.
Turn on the board and i notice that the init LED is red and the application never runs.
Any advice? I've read all the possible documents and followed every step. Still doesn't work.
Re: Boot from QSPI Flash on ZC706
Hi @wave85 :
Recheck again if you have not inverted SW11 settings:
QSPI mode: 00010 ---> Off Off Off On Off
Reference figure to check ON Off settings:
Check if it boots successfully from SD mode. (mode settings: 00110)
If issue persist, verify if BIST passes: https://www.xilinx.com/support/documentation/boards_and_kits/zc706/2015_4/ug961-zc706-GSG.pdf , Page 9 onwards. This will ensure about board health and will help to narrow down issue.
Priyanka
If you find any post has resolved your query, mark it as accepted solution.
