Newbie idan_s
DLC10 USB Driver Installation
I'm having an issue with installing the USB driver for the DLC10 kit. Is there a downloadable driver available? Windows 7 is unable to correctly install this device. Any help will be greatly appreciated (or if you could guide me to the appropriate forum discussion where this problem is solved)
Thanks!
Re: DLC10 USB Driver Installation
Can you install the lab tools available at the link below?
https://secure.xilinx.com/webreg/register.do?group=dlc&htmlfile=&emailFile=&cancellink=&eFrom=&eSubject=&version=14.7&akdm=1&filename=Xilinx_LabTools_14.7_1015_1.tar&local_cache=true
The information in the below AR may help to solve your issue
http://www.xilinx.com/support/answers/44397.html
http://www.xilinx.com/support/answers/41442.html
Newbie bagus_p
Hi, can i got driver DLC10 for windows 10 ? Im working with windows 10, please help...
Thankyou
@bagus_p
All these drivers are included in vivado installation directory. Please follow the steps mentioned on page#20 of
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug973-vivado-release-notes-install-license.pdf
Harshit
