Anonymous
Not applicable
Declaration of Conformity for Platform Cable USB II
There is CE marking on the device and one line in manual, that it is CE compliant, but no actual declaration of conformity.
Could you provide me with one?
Hello @Anonymous,
Vendor would be the right point of contact for you to get this thing.
Unfortunately, We do not hold any copy of this.
Thank you.
Hello @Anonymous,
Can you please elaborate what exactly do you expect ?
Do you want any documentation stating the same ?
Thank you.
Anonymous
Not applicable
I am expecting document similiar to thisDe
Declaration of Conformity is integral part of Conformité Européenne (CE marking) and required by most of the european countries.
Without it CE marking is not valid, also simple mentiones in manual like "Product is CE compliant" is not enough. In theory, products without whole CE package cannot be sold in most of Europe. Usually this Declaration is included in box, attached to manual or downloadable from manufacturer site.
Sorry if I sound unreasonably, but I am not a lawmaker ;]
Hello @Anonymous,
We understand and your request is valid.
After a brief discussion with some of the responsible folks for this I got to know that it will in the pack slip of the shipment.
If it's not there you can request warehouse or the vendor through which you have purchased the product.
Hope this helps.
Thank you.
Anonymous
Not applicable
Thank you for your reply!
Matter of fact is, I have the device already on my desk,
Do you think you could help me contact with people that can send me DoC in pdf form (I dont need physical copy)?
I can ask the vendor, but propably they will redirect this anyway.
Hello @Anonymous,
Thank you.
