Visitor atatt2020
Digilent PmodMIC with spartan 3E
Hello to all
I have a spartan 3E starter kit, and i need to input an audio signal to my project in FPGA, so i will buy the pmod mic
http://www.digilentinc.com/Products/Detail.cfm?NavTop=2&NavSub=517&Prod=PMOD-MIC  provided by DIGILENT.
my demand is there any document ar anything that provide information like:
 what is the frequency range of the recorded audio
 what is representation of the output (is it signed), also is it integer or fruction represented in fixed point (where is the binary point).
any information about that?
THANKS.
at
Historian
Historian
Re: Digilent PmodMIC with spartan 3E
atatt2020 wrote:
Hello to all
THANKS.
at
Please don't demand anything. Ask nicely ;)
The page to which you linked tells you exactly what ADC is on the board, and from that part's DATA SHEET you can determine the output data format.
As for frequency response, ask Digilent for a data sheet for the particular microphone they chose.
-a
Newbie phobik
I'm trying to interface the PmodMic, which has a custom IP provided by Digilent, and from my understanding I need to import this IP and create 3 logic signals and make them available as external ports of 1 bit each and map them to the correct pins in the FPGA indicated in the board reference manual.
I've tried to follow this tutorial here http://www.fpgadeveloper.com/2008/10/integrating-vhdl-design-into-peripheral.html but am having trouble in maping these control signals to the PmodModMic. If someone can provide some help it will be welcomed.
Thanks in advance.
Instructor
Instructor
Two suggestions:
1.  Start a new thread.  It is considered bad manners to insert a new topic or problem to an existing thread, which greatly confuses the discussion record.
2.  Have you contacted the good people at Digilent for guidance and support?  It would be helpful to you and to them if you would be as specific as possible in your question or problem description.
-- Bob Elkind
SIGNATURE:
Summary:
