Participant subu.rama
Error programming flash for qspi boot on ZCU102 Rev 1.1
I have a ZCU102 Rev 1.1 board and am following UG1209 embedded design tutorial.
I was successfully able to get up to the section titled "Running the Image in QSPI Boot Mode on ZCU102 Board" (in Chapter 5). When I try to program the flash I get:
****** Xilinx Program Flash
****** Program Flash v2018.3 (64-bit)
  **** SW Build 2405991 on Thu Dec  6 23:38:27 MST 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Connected to hw_server @ TCP:127.0.0.1:3121
Available targets and devices:
Target 0 : jsn-JTAG-SMT2NC-210308A7A2D1
	Device 0: jsn-JTAG-SMT2NC-210308A7A2D1-24738093-0
Retrieving Flash info...
Initialization done, programming the memory
===== mrd->addr=0xFF5E0204, data=0x00000000 =====
BOOT_MODE REG = 0x0000
Downloading FSBL...
Running FSBL...
Finished running FSBL.
Problem in running uboot
Flash programming initialization failed.
ERROR: Flash Operation Failed
The bif file I used for BOOT.bin is:
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
	[fsbl_config]a53_x64
	[bootloader]G:\zcu102\edt_zcu102\edt_zcu102.sdk\fsbl_a53\Debug\fsbl_a53.elf
	[destination_cpu = pmu]G:\zcu102\edt_zcu102\edt_zcu102.sdk\pmu_fw\Debug\pmu_fw.elf
	[destination_cpu = a53-0, exception_level = el-3, trustzone]G:\zcu102\ug1209-embedded-design-tutorial\qspi_boot\bl31.elf
	[destination_cpu = a53-0]G:\zcu102\edt_zcu102\edt_zcu102.sdk\testapp_r5\Debug\testapp_r5.elf
	[destination_cpu = a53-0, exception_level = el-2]E:\RHShared\qspi_boot\u-boot.elf
	[offset = 0x1E40000, destination_cpu = a53-0]E:\RHShared\qspi_boot\image.ub
When I am trying to program the flash, the SDK tries to switch to debug perspective with continuously showing the error:
Memory read error at 0x0. Cannot read 'sctlr_el3'. Cannot read 'r0'. Instruction transfer timeout.
I am new to Xilinx and any/all help is greatly appreciated.
Thank you
Subu
Re: Error programming flash for qspi boot on ZCU102 Rev 1.1
I used 2019.1 and was successfully able to complete booting from the flash.
Hi subu,
Take a look at these ARs:
https://www.xilinx.com/support/answers/71961.html
https://www.xilinx.com/support/answers/72210.html
Do you have a -05 ZCU102?
If that's the case, the solution would be to regenerate the FSBL with SDK 2018.3.
Andres
My board version is: 0432055-04-1842 (whizzysystems.com).
The HW revision is Z1-ZCU102 Rev 1.1
I have just installed 2019.1 and will try with that.
Thank you
Subu
