airturk
Exclusive PHY Access to the ARM Processor on ZC702 Development board
Dear Members;
 It is my understanding that PHY is exclusively connected to ARM processor on ZC702. if yes, Why?
Is there a way to mux this access so we can have custom logic (PL) connecting to it instead of the ARM?
Tags (3)
mcgett
> if yes, Why?
Because, the ZC702 is for evaluation of the Zynq-7000 with the ARM processor and the most likely use of ethernet would be using the integrated ethernet controller include the ARM processor system.
No.
mcgett
> if yes, Why?
No.
airturk
If you don't mind me asking, what is the plan for the upcoming development boards?
kyuchoe
I have the same issue. Our firmware uses the ethernet interface to communicate the FPGA. I would like to keep our design as much as possible. Is there any other efficient ways to program our custom logic to the PL through the ethernet interface?
clp510
I think you can use a FMC card which contain a PHY.
