FMC Vadj on ZCU106
I have a question of FMC Vadj of ZCU106.
Seeing in schematics, MAX15301 generates Vadj=1.8V in default.
When the other Vadj value is required, how does the system controller change Vadj?
Does it just issue VOUT_COMMAND for MAX15301?
BestRegards
u-sui
Hi @u-sui ,
Yes, VOUT_Command will get issued. This will be done with the help of MSP430 on Board.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @u-sui ,
Deepak D N
Hi D N
Thank you for your reply.
I understood.
BestRegards
u-sui
