Observer s_aelsok
FMC150 and ML605 board in System Generator.
I would like to use ML605 with the ADC from FMC150 card - in an application as simple as sampling a sinewave for example and displaying the result on a scope in simulink. I need to preform a HW-cosim using point-to-point ethernet using a free running clock; for which I have done the output interface using a shared memory configured as FIFO.
I went through the datasheets for the ADS62P49 and CDCE72010 , I've also read the vhdl code from the getting started reference design for the ML605 DSP kit, extracted what I need for the operation of the ADC.
So now I need to import the vhdl file (for ADC interface) into a blackbox in sysgen.
1-How to set the constraints for this (ADC) block ?
(i.e. how to set the clk_ab_p, clk_ab_n, cha_p and cha_n in the getting started reference design for example to the corresponding ports of the FMC150?  - like adding a UCF file )
2-Is it possible to import the mmcm  blocks?  and how to make the clock of my design an output of the mmcm ?
3-Is it possible to get rid of the mmcm blocks in the getting started reference design if I use a sampling frequency equal to the clock frequency (say 100 MSPS  and 100 MHz clock) ?
4-If there is any simpler way to do this, please provide me with your suggestions.
Thanks in advance,
Ahmed.
Observer s_aelsok
Re: FMC150 and ML605 board in System Generator.
Hi Gabriel,
I found an alternative solution for this,
what I did is defining a new implementation target in system generator - in which you can select your clock port. Then I added the outputs of the ADC as non memory mapped ports. and I added a blackbox only for the IDDR buffer, for turning the DDR format of the LVDS_25 buffer into SDR.
However I am facing currently a problem of how to define a port in system generator as LVDS. as when I add this LVDS buffer as a blackbox, the system generator would give me an error , because it would infer the input port connected to this buffer as a single ended input buffer , and gives me an error that It is not allowed to have 2 input buffers connected in a row.
and when I try to specify that in the UCF file associated with the target that I defined, I get an error that the input non-memory mapped port is single ended and the UCF staes the constraint that it should be differential.
I just posted this porblem here : http://forums.xilinx.com/t5/DSP-Tools/LVDS-buffer-for-sysgen/td-p/221831
but so far no answer.
any other solutions in mind ?
Best regards,
Ahmed.
Hello Ahmed,
Did you carry on with this idea? I am now facing exactly the same problem, but I am about to move away and try an alternative solution for my problem..
Gabriel
Observer s_aelsok
Hi Gabriel,
Best regards,
Ahmed.
