05-29-2019 11:59 PM
I was trying to build the SDSoC colordetect acceleration demo project according to the SDSoC Environment Tutorial: Migrate OpenCV to xfOpenCV(https://github.com/Xilinx/SDSoC-Tutorials/blob/master/opencv-to-xfopencv-migration-tutorial/lab2-build-sdsoc-acceleration-project.md). There are lots of the such similar errors:
Analyzing source for RTL template usage
error: unable to handle compilation, expected exactly one compiler job in ''
Error while processing F:\Environment_Tutorial\color_detect\Release\1.
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:38:9: error: unknown type name '__Int8x8_t'
typedef __Int8x8_t int8x8_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:39:9: error: unknown type name '__Int16x4_t'
typedef __Int16x4_t int16x4_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:40:9: error: unknown type name '__Int32x2_t'; did you mean '__int32_t'?
typedef __Int32x2_t int32x2_t;
__int32_t
F:\zcu104-rv-ss-2018-3\zcu104_rv_ss\sw\a53_linux\a53_linux\sysroot\aarch64-xilinx-linux/usr/include\bits/types.h:40:20: note: '__int32_t' declared here
typedef signed int __int32_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:41:9: error: unknown type name '__Int64x1_t'; did you mean '__int64_t'?
typedef __Int64x1_t int64x1_t;
__int64_t
F:\zcu104-rv-ss-2018-3\zcu104_rv_ss\sw\a53_linux\a53_linux\sysroot\aarch64-xilinx-linux/usr/include\bits/types.h:43:25: note: '__int64_t' declared here
typedef signed long int __int64_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:42:9: error: unknown type name '__Float16x4_t'
typedef __Float16x4_t float16x4_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:43:9: error: unknown type name '__Float32x2_t'
typedef __Float32x2_t float32x2_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:44:9: error: unknown type name '__Poly8x8_t'
typedef __Poly8x8_t poly8x8_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:45:9: error: unknown type name '__Poly16x4_t'
typedef __Poly16x4_t poly16x4_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:46:9: error: unknown type name '__Uint8x8_t'
typedef __Uint8x8_t uint8x8_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:47:9: error: unknown type name '__Uint16x4_t'
typedef __Uint16x4_t uint16x4_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:48:9: error: unknown type name '__Uint32x2_t'
typedef __Uint32x2_t uint32x2_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:49:9: error: unknown type name '__Float64x1_t'
typedef __Float64x1_t float64x1_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:50:9: error: unknown type name '__Uint64x1_t'
typedef __Uint64x1_t uint64x1_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:51:9: error: unknown type name '__Int8x16_t'; did you mean '__int16_t'?
typedef __Int8x16_t int8x16_t;
__int16_t
F:\zcu104-rv-ss-2018-3\zcu104_rv_ss\sw\a53_linux\a53_linux\sysroot\aarch64-xilinx-linux/usr/include\bits/types.h:38:26: note: '__int16_t' declared here
typedef signed short int __int16_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:52:9: error: unknown type name '__Int16x8_t'
typedef __Int16x8_t int16x8_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:53:9: error: unknown type name '__Int32x4_t'; did you mean '__int32_t'?
typedef __Int32x4_t int32x4_t;
__int32_t
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:54:9: error: unknown type name '__Int64x2_t'; did you mean '__int64_t'?
typedef __Int64x2_t int64x2_t;
__int64_t
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:55:9: error: unknown type name '__Float16x8_t'
typedef __Float16x8_t float16x8_t;
E:/SDX/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:56:9: error: unknown type name '__Float32x4_t'
typedef __Float32x4_t float32x4_t;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
Error while processing F:\Environment_Tutorial\color_detect\src\colordetect.cpp.
ERROR: [TemplateExtract 83-3509] Failed to run clang frontend action of rtl_template_extract!
ERROR: [SdsCompiler 83-5176] RTL template analysis exited with non-zero code processing F:/Environment_Tutorial/color_detect/Release/1 F:/Environment_Tutorial/color_detect/src/colordetect.cpp
sds++ log file saved as F:/Environment_Tutorial/color_detect/Release/_sds/reports/sds_colordetect.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/subdir.mk:26: src/colordetect.o] Error 1
22:01:23 Build Finished (took 8s.78ms)
Either the version of my SDSoC and reVISION Stack is 2018.3.
How can i solve this problem?
Please help me. Many thanks in advance.
