fabiend
Flash issue on board Spartan 3A DSP 3400.
I have an issue when I tried to boot my program using the Flash Memory. I'm using the board spartan 3A-DSP 3400, and when I want to program my flash memory (using EDK), I have this error message:
"* Opening image file to be programmed...done.
* Setting up Flashwriter sources for compilation...
* Performing CFI Query on the flash part(s)...
* ERROR: Flashwriter application reported an error: Unable to successfully query target part layout using CFI!
* Flashwriter terminating !
Done!"
Do you know how can I solve this issue ?
Best Regards,
Fabien
tushar_dongre
The supported flash architecture is mentioned in the document est_rm.pdf (http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/est_rm.pdf).
Make sure the FLASH is CFI complaint. You can compare the datasheet of flash with the Intel Strata flash device 28F256J3.
tushar_dongre
