Observer jmcoreymv
Help! Unable to boot the ZCU111 with the PYNQ v2.4 image
I've been struggling trying to get the ZCU111 board to boot off an SD card with the Pynq v2.4 image.  I was able to get this working in the past (~1 month ago), but now the boot process never seems to complete.  It either stops at a few common points, or stack dumps/exception traces.
I've tried:
- 2 different ZCU111 boards.  These boards are able to boot the QSPI self-test image and the RF DC Eval tool image.
- 4 different SD cards (2 of which came with the ZCU111 boards, and a 3rd which worked in the past for PYNQ)
- Burning the SD image from two different Windows 10 PCs using both Win32 Disk Imager and Balena Etcher
- Re-downloading the Pynq v2.4 ZCU111 image from Xilinx's website multiple times.
- Posting on the PYNQ forums, but no luck yet.
Here is a typical boot log and where it commonly stops:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.3   Feb 21 2019  -  20:07:53
NOTICE:  ATF running on XCZU28DR/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.5(release):xilinx-v2018.2-919-g08560c36
NOTICE:  BL31: Built : 20:11:08, Feb 21 2019
PMUFW:  v1.1
U-Boot 2018.01 (Feb 21 2019 - 20:05:05 +0000) Xilinx ZynqMP ZCU111
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu28dr
MMC:   mmc@ff170000: 0 (SD)
SF: Detected mt25qu02g with page size 512 Bytes, erase size 128 KiB, total 512 MiB
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU111 RevA
Board: Xilinx ZynqMP
Bootmode: LVL_SHFT_SD_MODE1
U-BOOT for xilinx-zcu111-2018_3
Device: mmc@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
14886772 bytes read in 976 ms (14.5 MiB/s)
   Using 'conf@1' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d4
     Data Size:    14838272 Bytes = 14.2 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   65ef692958d77aaedcd87847fecb1e6980146ce4
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10e26bcc
     Data Size:    47199 Bytes = 46.1 KiB
     Hash algo:    sha1
     Hash value:   f84d8843a36a4c6797dec68acfdd4957538074ee
   Booting using the fdt blob at 0x10e26bcc
   Loading Kernel Image ... OK
   Loading Device Tree to 0000000007ff1000, end 0000000007fff85e ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.3 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP Thu Feb 21 19:59:32 UTC 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP ZCU111 RevA
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x0000000077c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff61000 s46232 r8192 d31592 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1031940
[    0.000000] Kernel command line: root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait devtmpfs.mount=1 uio_pdrv_genirq.of_id="generic-uio" clk_ignore_unused
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x73c00000-0x77c00000] (64MB) mapped at [ffffffc073c00000-ffffffc077bfffff]
[    0.000000] Memory: 3906992K/4193280K available (10108K kernel code, 666K rwdata, 3136K rodata, 512K init, 2361K bss, 155216K reserved, 131072K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a60000   ( 10112 KB)
[    0.000000]     .rodata : 0xffffff8008a60000 - 0xffffff8008d80000   (  3200 KB)
[    0.000000]       .init : 0xffffff8008d80000 - 0xffffff8008e00000   (   512 KB)
[    0.000000]       .data : 0xffffff8008e00000 - 0xffffff8008ea6a00   (   667 KB)
[    0.000000]        .bss : 0xffffff8008ea6a00 - 0xffffff80090f4f30   (  2362 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf22000000   (   544 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.000343] Console: colour dummy device 80x25
[    0.000625] console [tty0] enabled
[    0.000644] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.000659] pid_max: default: 32768 minimum: 301
[    0.000782] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.000801] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001427] ASID allocator initialised with 65536 entries
[    0.001482] Hierarchical SRCU implementation.
[    0.001829] EFI services will not be available.
[    0.001856] zynqmp_plat_init Platform Management API v1.1
[    0.001865] zynqmp_plat_init Trustzone version v1.0
[    0.001970] smp: Bringing up secondary CPUs ...
[    0.178856] Detected VIPT I-cache on CPU1
[    0.178884] CPU1: Booted secondary processor [410fd034]
[    0.290779] Detected VIPT I-cache on CPU2
[    0.290797] CPU2: Booted secondary processor [410fd034]
[    0.416075] Detected VIPT I-cache on CPU3
[    0.416092] CPU3: Booted secondary processor [410fd034]
[    0.416134] smp: Brought up 1 node, 4 CPUs
[    0.416173] SMP: Total of 4 processors activated.
[    0.416182] CPU features: detected feature: 32-bit EL0 Support
[    0.416204] CPU: All CPU(s) started at EL2
[    0.416222] alternatives: patching kernel code
[    0.416985] devtmpfs: initialized
[    0.421962] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.421982] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.424873] xor: measuring software checksum speed
[    0.464273]    8regs     :  2303.000 MB/sec
[    0.504303]    8regs_prefetch:  2053.000 MB/sec
[    0.544331]    32regs    :  2830.000 MB/sec
[    0.584363]    32regs_prefetch:  2379.000 MB/sec
[    0.584371] xor: using function: 32regs (2830.000 MB/sec)
[    0.584436] pinctrl core: initialized pinctrl subsystem
[    0.584944] NET: Registered protocol family 16
[    0.585585] cpuidle: using governor menu
[    0.586187] vdso: 2 pages (1 code @ ffffff8008a66000, 1 data @ ffffff8008e04000)
[    0.586204] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.586673] DMA: preallocated 256 KiB pool for atomic allocations
[    0.607610] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.608152] ARM CCI_400_r1 PMU driver probed
[    0.612854] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.620799] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.688502] raid6: int64x1  gen()   399 MB/s
[    0.756525] raid6: int64x1  xor()   444 MB/s
[    0.824645] raid6: int64x2  gen()   684 MB/s
[    0.892645] raid6: int64x2  xor()   603 MB/s
[    0.960688] raid6: int64x4  gen()  1041 MB/s
[    1.028744] raid6: int64x4  xor()   742 MB/s
[    1.096808] raid6: int64x8  gen()   980 MB/s
[    1.164853] raid6: int64x8  xor()   745 MB/s
[    1.232896] raid6: neonx1   gen()   727 MB/s
[    1.300929] raid6: neonx1   xor()   853 MB/s
[    1.369010] raid6: neonx2   gen()  1168 MB/s
[    1.437029] raid6: neonx2   xor()  1208 MB/s
[    1.505095] raid6: neonx4   gen()  1505 MB/s
[    1.573111] raid6: neonx4   xor()  1442 MB/s
[    1.641164] raid6: neonx8   gen()  1652 MB/s
[    1.709206] raid6: neonx8   xor()  1533 MB/s
[    1.709214] raid6: using algorithm neonx8 gen() 1652 MB/s
[    1.709222] raid6: .... xor() 1533 MB/s, rmw enabled
[    1.709229] raid6: using neon recovery algorithm
[    1.710710] SCSI subsystem initialized
[    1.710880] usbcore: registered new interface driver usbfs
[    1.710918] usbcore: registered new interface driver hub
[    1.710957] usbcore: registered new device driver usb
[    1.711016] media: Linux media interface: v0.10
[    1.711041] Linux video capture interface: v2.00
[    1.711085] pps_core: LinuxPPS API ver. 1 registered
[    1.711093] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.711112] PTP clock support registered
[    1.711139] EDAC MC: Ver: 3.0.0
[    1.711438] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.711587] FPGA manager framework
[    1.711694] fpga-region fpga-full: FPGA Region probed
[    1.711790] Advanced Linux Sound Architecture Driver Initialized.
[    1.712037] Bluetooth: Core ver 2.22
[    1.712067] NET: Registered protocol family 31
[    1.712093] Bluetooth: HCI device and connection manager initialized
[    1.712106] Bluetooth: HCI socket layer initialized
[    1.712116] Bluetooth: L2CAP socket layer initialized
[    1.712135] Bluetooth: SCO socket layer initialized
[    1.712698] clocksource: Switched to clocksource arch_sys_counter
[    1.712787] VFS: Disk quotas dquot_6.6.0
[    1.712831] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.717354] NET: Registered protocol family 2
[    1.717659] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.717869] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.718282] TCP: Hash tables configured (established 32768 bind 32768)
[    1.718357] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.718435] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.718598] NET: Registered protocol family 1
[    1.718773] RPC: Registered named UNIX socket transport module.
[    1.718783] RPC: Registered udp transport module.
[    1.718790] RPC: Registered tcp transport module.
[    1.718797] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.719284] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.719436] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.720094] audit: initializing netlink subsys (disabled)
[    1.720425] audit: type=2000 audit(1.712:1): state=initialized audit_enabled=0 res=1
[    1.720470] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.721490] NFS: Registering the id_resolver key type
[    1.721510] Key type id_resolver registered
[    1.721518] Key type id_legacy registered
[    1.721530] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.721550] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.745195] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.745216] io scheduler noop registered
[    1.745223] io scheduler deadline registered
[    1.745250] io scheduler cfq registered (default)
[    1.745258] io scheduler mq-deadline registered
[    1.745266] io scheduler kyber registered
[    1.746506] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.746865] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.747022] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.747176] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.747332] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.747487] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.747642] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.747802] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.747958] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.748183] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.748339] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.748493] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.748648] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.748903] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.749061] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.749215] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.749373] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.774586] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.777596] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.781635] brd: module loaded
[    1.785029] loop: module loaded
[    1.785462] xilinx-sdfec a0040000.sd-fec: XSDFEC0 Probe Successful
[    1.786041] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
[    1.786197] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.787032] m25p80 spi0.0: found mt25ul02g, expected n25q512a
[    1.787248] m25p80 spi0.0: mt25ul02g (524288 Kbytes)
[    1.787272] 4 ofpart partitions found on MTD device spi0.0
[    1.787280] Creating 4 MTD partitions on "spi0.0":
[    1.787291] 0x000000000000-0x000001e00000 : "boot"
[    1.787707] 0x000001e00000-0x000001e40000 : "bootenv"
[    1.788081] 0x000001e40000-0x000004240000 : "kernel"
[    1.788461] 0x000004240000-0x000020000000 : "spare"
[    1.789734] libphy: Fixed MDIO Bus: probed
[    1.790697] tun: Universal TUN/TAP device driver, 1.6
[    1.790849] CAN device driver interface
[    1.792305] macb ff0e0000.ethernet: Not enabling partial store and forward
[    1.792341] macb ff0e0000.ethernet: invalid hw address, using random
[    1.792813] libphy: MACB_mii_bus: probed
[    1.793323] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (3e:0e:3e:89:5e:19)
[    1.793339] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[    1.794024] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    1.795269] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.795280] ehci-pci: EHCI PCI platform driver
[    1.795562] usbcore: registered new interface driver cdc_acm
[    1.795572] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.795603] usbcore: registered new interface driver cdc_wdm
[    1.795642] usbcore: registered new interface driver usb-storage
[    1.795695] usbcore: registered new interface driver usbserial
[    1.795723] usbcore: registered new interface driver usbserial_generic
[    1.795748] usbserial: USB Serial support registered for generic
[    1.795776] usbcore: registered new interface driver usb_serial_simple
[    1.795800] usbserial: USB Serial support registered for carelink
[    1.795827] usbserial: USB Serial support registered for zio
[    1.795850] usbserial: USB Serial support registered for funsoft
[    1.795873] usbserial: USB Serial support registered for flashloader
[    1.795898] usbserial: USB Serial support registered for google
[    1.795922] usbserial: USB Serial support registered for vivopay
[    1.795945] usbserial: USB Serial support registered for moto_modem
[    1.795970] usbserial: USB Serial support registered for novatel_gps
[    1.795994] usbserial: USB Serial support registered for hp4x
[    1.796018] usbserial: USB Serial support registered for suunto
[    1.796042] usbserial: USB Serial support registered for siemens_mpi
[    1.796539] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    1.796593] i2c /dev entries driver
[    1.797621] IR NEC protocol handler initialized
[    1.797631] IR RC5(x/sz) protocol handler initialized
[    1.797638] IR RC6 protocol handler initialized
[    1.797645] IR JVC protocol handler initialized
[    1.797652] IR Sony protocol handler initialized
[    1.797659] IR SANYO protocol handler initialized
[    1.797666] IR Sharp protocol handler initialized
[    1.797673] IR MCE Keyboard/mouse protocol handler initialized
[    1.797681] IR XMP protocol handler initialized
[    1.799363] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff8009175000 with timeout 60s
[    1.799604] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at ffffff800917d000 with timeout 10s
[    1.799785] Bluetooth: HCI UART driver ver 2.3
[    1.799795] Bluetooth: HCI UART protocol H4 registered
[    1.799803] Bluetooth: HCI UART protocol BCSP registered
[    1.799830] Bluetooth: HCI UART protocol LL registered
[    1.799839] Bluetooth: HCI UART protocol ATH3K registered
[    1.799847] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.799892] Bluetooth: HCI UART protocol Intel registered
[    1.799900] Bluetooth: HCI UART protocol QCA registered
[    1.799941] usbcore: registered new interface driver bcm203x
[    1.799973] usbcore: registered new interface driver bpa10x
[    1.800009] usbcore: registered new interface driver bfusb
[    1.800044] usbcore: registered new interface driver btusb
[    1.800052] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.800100] usbcore: registered new interface driver ath3k
[    1.800225] EDAC MC: ECC not enabled
[    1.800379] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    1.801293] sdhci: Secure Digital Host Controller Interface driver
[    1.801304] sdhci: Copyright(c) Pierre Ossman
[    1.801311] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.844712] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[    1.850731] ledtrig-cpu: registered to indicate activity on CPUs
[    1.850877] usbcore: registered new interface driver usbhid
[    1.850886] usbhid: USB HID core driver
[    1.850991] xlnk xlnk: Major 244
[    1.851102] xlnk xlnk: xlnk driver loaded
[    1.851112] xlnk xlnk: xlnk_pdev is not null
[    1.853916] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    1.856301] usbcore: registered new interface driver snd-usb-audio
[    1.857050] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.857321] Netfilter messages via NETLINK v0.30.
[    1.857443] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.857585] Initializing XFRM netlink socket
[    1.857663] NET: Registered protocol family 10
[    1.858078] Segment Routing with IPv6
[    1.858125] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.858314] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.858624] NET: Registered protocol family 17
[    1.858640] NET: Registered protocol family 15
[    1.858661] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.858675] Ebtables v2.0 registered
[    1.858769] can: controller area network core (rev 20170425 abi 9)
[    1.858804] NET: Registered protocol family 29
[    1.858813] can: raw protocol (rev 20170425)
[    1.858821] can: broadcast manager protocol (rev 20170425 t)
[    1.858831] can: netlink gateway (rev 20170425) max_hops=1
[    1.859032] Bluetooth: RFCOMM TTY layer initialized
[    1.859044] Bluetooth: RFCOMM socket layer initialized
[    1.859060] Bluetooth: RFCOMM ver 1.11
[    1.859070] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.859078] Bluetooth: BNEP filters: protocol multicast
[    1.859088] Bluetooth: BNEP socket layer initialized
[    1.859096] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.859106] Bluetooth: HIDP socket layer initialized
[    1.859220] 9pnet: Installing 9P2000 support
[    1.859240] Key type dns_resolver registered
[    1.859671] registered taskstats version 1
[    1.861036] Btrfs loaded, crc32c=crc32c-generic
[    1.867708] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 41, base_baud = 6249999) is a xuartps
[    2.552302] mmc0: new high speed SDHC card at address aaaa
[    2.559006] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    2.615563]  mmcblk0: p1 p2
[    3.523156] console [ttyPS0] enabled
[    3.668658] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 42, base_baud = 6249999) is a xuartps
[    3.679419] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[    3.753297] PLL: shutdown
[    3.756004] PLL: shutdown
[    3.759020] PLL: enable
[    3.761567] PLL: shutdown
[    3.765131] PLL: enable
[    3.767660] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    3.778335] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    3.786363] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    3.794684] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.807119] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.819780] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.829959] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.836954] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.843567] [drm] No driver support for vblank timestamp query.
[    3.849547] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b19c68)
[    4.936715] [drm] Cannot find any crtc or sizes
[    4.941414] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[    4.949519] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[    4.958474] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[    4.966365] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    4.975327] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    4.991770] scsi host0: ahci-ceva
[    4.995280] scsi host1: ahci-ceva
[    4.998688] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 39
[    5.006610] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 39
[    5.016332] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[    5.026359] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    5.031860] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    5.039721] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010810
[    5.048451] xhci-hcd xhci-hcd.0.auto: irq 49, io mem 0xfe200000
[    5.054493] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.061309] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.068530] usb usb1: Product: xHCI Host Controller
[    5.073405] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.3 xhci-hcd
[    5.080098] usb usb1: SerialNumber: xhci-hcd.0.auto
[    5.085254] hub 1-0:1.0: USB hub found
[    5.089028] hub 1-0:1.0: 1 port detected
[    5.093128] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    5.098620] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    5.106394] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    5.113183] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.120402] usb usb2: Product: xHCI Host Controller
[    5.125277] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.3 xhci-hcd
[    5.131970] usb usb2: SerialNumber: xhci-hcd.0.auto
[    5.137079] hub 2-0:1.0: USB hub found
[    5.140843] hub 2-0:1.0: 1 port detected
[    5.145847] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[    5.155818] pca953x 0-0020: interrupt support not compiled in
[    5.162353] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    5.169129] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.175903] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.182672] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.189448] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.196216] ina2xx 3-0046: power monitor ina226 (Rshunt = 2000 uOhm)
[    5.202999] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.209766] ina2xx 3-0048: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.216538] ina2xx 3-0049: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.223314] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.230084] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.236863] ina2xx 3-004c: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.243639] ina2xx 3-004d: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.250424] ina2xx 3-004e: power monitor ina226 (Rshunt = 5000 uOhm)
[    5.256804] i2c i2c-0: Added multiplexed i2c bus 3
[    5.261728] i2c i2c-0: Added multiplexed i2c bus 4
[    5.266833] i2c i2c-0: Added multiplexed i2c bus 5
[    5.271745] i2c i2c-0: Added multiplexed i2c bus 6
[    5.276541] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    5.283870] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[    5.291417] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    5.298147] i2c i2c-1: Added multiplexed i2c bus 7
[    5.303115] i2c i2c-1: Added multiplexed i2c bus 8
[    5.309953] si570 9-005d: registered, current frequency 300000000 Hz
[    5.316330] i2c i2c-1: Added multiplexed i2c bus 9
[    5.330924] ata2: SATA link down (SStatus 0 SControl 330)
[    5.335080] si570 10-005d: registered, current frequency 148500000 Hz
[    5.335109] i2c i2c-1: Added multiplexed i2c bus 10
[    5.335290] i2c i2c-1: Added multiplexed i2c bus 11
[    5.335472] i2c i2c-1: Added multiplexed i2c bus 12
[    5.335596] i2c i2c-1: Added multiplexed i2c bus 13
[    5.335707] i2c i2c-1: Added multiplexed i2c bus 14
[    5.335711] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    5.336018] i2c i2c-1: Added multiplexed i2c bus 15
[    5.336138] i2c i2c-1: Added multiplexed i2c bus 16
[    5.336257] i2c i2c-1: Added multiplexed i2c bus 17
[    5.336684] i2c i2c-1: Added multiplexed i2c bus 18
[    5.336818] i2c i2c-1: Added multiplexed i2c bus 19
[    5.336941] i2c i2c-1: Added multiplexed i2c bus 20
[    5.337064] i2c i2c-1: Added multiplexed i2c bus 21
[    5.337186] i2c i2c-1: Added multiplexed i2c bus 22
[    5.337190] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    5.337214] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[    5.338432] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.342760] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-12-21 18:55:14 UTC (1545418514)
[    5.342763] of_cfs_init
[    5.342783] of_cfs_init: OK
[    5.342917] clk: Not disabling unused clocks
[    5.343143] ALSA device list:
[    5.343145]   #0: DisplayPort monitor
[    5.459051] ata1: SATA link down (SStatus 0 SControl 330)
[    5.661345] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.669456] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    5.847105] devtmpfs: mounted
[    5.850194] Freeing unused kernel memory: 512K
[    6.108711] [drm] Cannot find any crtc or sizes
Sometimes it gets slightly further with:
[    5.387708] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    5.543783] devtmpfs: mounted
[    5.546879] Freeing unused kernel memory: 512K
[    5.864723] [drm] Cannot find any crtc or sizes
[    9.706764] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    9.728301] systemd[1]: Detected architecture arm64.
Welcome to PYNQ Linux, based on Ubuntu 18.04!
[    9.769477] systemd[1]: Set hostname to <pynq>.
[   20.704711] mmc0: Timeout waiting for hardware interrupt.
[   20.710107] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   20.716536] mmc0: sdhci: Sys addr:  0x00000008 | Version:  0x00001002
[   20.722966] mmc0: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
[   20.729398] mmc0: sdhci: Argument:  0x00001000 | Trn mode: 0x0000003b
[   20.735830] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001f
[   20.742262] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
[   20.748694] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
[   20.755126] mmc0: sdhci: Timeout:   0x00000004 | Int stat: 0x00000003
[   20.761558] mmc0: sdhci: Int enab:  0x02ff008b | Sig enab: 0x02ff008b
[   20.767990] mmc0: sdhci: AC12 err:  0x00000000 | Slot int: 0x00000001
[   20.774422] mmc0: sdhci: Caps:      0x35ecc881 | Caps_1:   0x00002007
[   20.780854] mmc0: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
[   20.787286] mmc0: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
[   20.793718] mmc0: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
[   20.800149] mmc0: sdhci: Host ctl2: 0x00000000
[   20.804585] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000077c4020c
[   20.811711] mmc0: sdhci: ============================================
If I stop the boot process and type mmcinfo:
ZynqMP> mmcinfo
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Any help is greatly appreciated.  Thanks.
