Observer adavappa
How many internal ADC's are available in ZCU102 Board
Hi Team,
I wanted to know , how many ADC's are there on the ZCU102 board and if ADC's are there can we use them for our application purpose. If any hardware spec is available for the same, please share.
Expecting quick response.
Thanks you.
Observer adavappa
Re: How many internal ADC's are available in ZCU102 Board
Thank you for the information.
Hi @adavappa
ZCU102 haveZynq UltraScale+ XCZU9EG-2FFVB1156 MPSoC device which have PL and PS Sysmon.
The SYSMON includes an analog-to-digital converter (ADC) as well as on-chip sensors that can be used to sample external voltages and monitor on-die operating conditions, such as temperature and supply voltage levels.
We do have detailed board user guide and user guide for SYSMON , I wonder if can refer to these guides for detailed information
https://www.xilinx.com/products/boards-and-kits/ek-u1-zcu102-g.html#hardware
https://www.xilinx.com/support/documentation/user_guides/ug580-ultrascale-sysmon.pdf
Also do refer technica refference manual when using MPSoC device based boards
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
Observer adavappa
