How to check jumper setting (TDO-TDI)?
I try to use XM105 for debugging  the signal from KCU105 evaluation borad.
I connected XM105 to KCU105. Aftert XM105 connection, I cannot open device from vivado. However, disconnecting XM105, I can open device.
I try to check jumper settings at XM105 board. but I don't know check jumper setting.
How to check jumper setting?
Re: How to check jumper setting (TDO-TDI)?
@ysjung
On the XM105 board, look for a set of pins with the label "J5".  Make an electrical connection between pins 6 and 7.
https://www.xilinx.com/support/answers/52888.html
https://www.xilinx.com/support/documentation/boards_and_kits/ug537.pdf
Ted Booth - Tech. Lead FPGA Design Engineer
https://www.designlinxhs.com
@ysjung
