01-22-2020 07:57 AM - edited 02-10-2020 12:52 AM
https://www.digikey.com/product-detail/en/ams/TSL1412S/TSL1412-S-ND/3095067
How to connect Spartan 3E starter board TLS1412S linear array sensor?
How can we read from the ADC port?
Does anyone have an idea?
Thanks in advance.
01-22-2020 01:20 PM
Thats now the digilent board,
They have some great docs and a support forum
https://reference.digilentinc.com/_media/s3e:s3estarter_ug.pdf
https://reference.digilentinc.com/_media/s3e:spartan-3e_sch.pdf
https://forum.digilentinc.com/
I'd suggest you start with the referance design for the board, found here
https://reference.digilentinc.com/reference/programmable-logic/spartan-3e/start?redirect=1
That will give you an idea of the many inerfaces this board has,
As a clue, the 6 PMOD connectors might be of interest, but you will find out about them in detail fomr the reference designs, build them and then you will be able to ask a more detailed quesiton,
01-22-2020 09:09 AM
01-22-2020 11:24 AM
I did not understand how to make a physical connection. There are analog input, clk, SI and Hold connections on TLS1412s.
There is only adc entry on Spartan 3e.
01-22-2020 11:32 AM
Which Spartan 3 board do you have ?
01-22-2020 11:39 AM
SPARTAN 3E STARTER
(xcs500e-4fg320)
01-22-2020 01:20 PM
02-21-2020 11:44 PM
# Spartan-3E Starter Board
Net fpga_0_RS232_DCE_RX_pin LOC=R7 | IOSTANDARD = LVCMOS33;
Net fpga_0_RS232_DCE_TX_pin LOC=M14 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<0> LOC=F9 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<1> LOC=E9 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<2> LOC=D11 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<3> LOC=C11 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<4> LOC=F11 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<5> LOC=E11 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<6> LOC=E12 | IOSTANDARD = LVCMOS33;
Net fpga_0_LEDS_GPIO_IO_O_pin<7> LOC=F12 | IOSTANDARD = LVCMOS33;
Net fpga_0_clk_1_sys_clk_pin TNM_NET = sys_clk_pin;
TIMESPEC TS_sys_clk_pin = PERIOD sys_clk_pin 50000 kHz;
Net fpga_0_clk_1_sys_clk_pin LOC=c9 | IOSTANDARD = LVCMOS33;
Net fpga_0_rst_1_sys_rst_pin TIG;
LOC=K17 | IOSTANDARD = LVCMOS33 | PULLDOWN;
NET button_pin LOC = L17;
NET clk_lineer_GPIO_IO_pin LOC = D7 | IOSTANDARD = LVCMOS33 | SLEW = FAST | DRIVE = 8 ;
NET si_lineer_GPIO_IO_pin LOC = C7 | IOSTANDARD = LVCMOS33 | SLEW = FAST | DRIVE = 8 ;
C code
* Copyright (c) 2009-2012 Xilinx, Inc. All rights reserved.
* Xilinx, Inc.
* XILINX IS PROVIDING THIS DESIGN, CODE, OR INFORMATION "AS IS" AS A
* COURTESY TO YOU. BY PROVIDING THIS DESIGN, CODE, OR INFORMATION AS
* ONE POSSIBLE IMPLEMENTATION OF THIS FEATURE, APPLICATION OR
* STANDARD, XILINX IS MAKING NO REPRESENTATION THAT THIS IMPLEMENTATION
* IS FREE FROM ANY CLAIMS OF INFRINGEMENT, AND YOU ARE RESPONSIBLE
* FOR OBTAINING ANY RIGHTS YOU MAY REQUIRE FOR YOUR IMPLEMENTATION.
* XILINX EXPRESSLY DISCLAIMS ANY WARRANTY WHATSOEVER WITH RESPECT TO
* THE ADEQUACY OF THE IMPLEMENTATION, INCLUDING BUT NOT LIMITED TO
* ANY WARRANTIES OR REPRESENTATIONS THAT THIS IMPLEMENTATION IS FREE
* FROM CLAIMS OF INFRINGEMENT, IMPLIED WARRANTIES OF MERCHANTABILITY
* AND FITNESS FOR A PARTICULAR PURPOSE.
* helloworld.c: simple test application
* This application configures UART 16550 to baud rate 9600.
* PS7 UART (Zynq) is not initialized by this application, since
* bootrom/bsp configures it to baud rate 115200
* | UART TYPE BAUD RATE |
* uartns550 9600
* uartlite Configurable only in HW design
* ps7_uart 115200 (configured by bootrom/bsp)
#include <stdio.h>
#include "platform.h"
#include "xparameters.h"
#include "xgpio.h"
#include <string.h>
#include "xdsadc.h"
/************************** Constant Definitions *****************************/
* The following constants map to the XPAR parameters created in the
* xparameters.h file. They are defined here such that a user can easily
* change all the needed parameters in one place.
#define DSADC_DEVICE_ID XPAR_ADC_0_DEVICE_ID
#define TEST_LENGTH 256 /* Length of the Test Data */
#define FSTM_VALUE 0x04 /* Intial value of the FSTM Register */
int DsAdcPolledExample(u16 DeviceId);
/************************** Variable Definitions *****************************/
static XDsAdc DsAdc; /* Instance of the ADC Device */
u16 RxData[TEST_LENGTH]; /* Buffer for storing the converted data */
static u16 *RxDataPtr = RxData; /* Pointer to the receive buffer */
static u32 RxDataLength = 0; /* Variable for storing Rx data length */
void print(char *str);
void SamplingDelay()
int ii;
for( ii=0;ii<5000;ii++);
int Status;
u32 IsrStatus;
XDsAdc *InstancePtr = &DsAdc;
* First Initialize the device.
Status = XDsAdc_Initialize(InstancePtr, DeviceId);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
* Set the FSTM register to a usable value.
XDsAdc_SetFstmReg(InstancePtr, FSTM_VALUE);
* Enable the conversion process in the DSADC.
XDsAdc_EnableConversion(InstancePtr);
* Wait for the data to complete.
do {
if (XDsAdc_IsEmpty(InstancePtr) != TRUE) {
*RxDataPtr++ = XDsAdc_ReadInput(InstancePtr);
RxDataLength++;
* Since the bit indicating that the ADC is finished
* converting a sample in located in the IPISR, the
* clearing of the bit is just like clearing the bit in
* interrupt driven mode.
IsrStatus = XDsAdc_GetInterruptStatus(InstancePtr);
XDsAdc_ClearInterruptStatus(InstancePtr, IsrStatus);
} while (RxDataLength <= TEST_LENGTH);
/*int i=0;
u16 dene=0;
for (i=0;i<256;i++)
u16 dene=0;
dene= RxDataPtr[i];
return XST_SUCCESS;
int main()
int Status;
unsigned char i;
XGpio clksensor,sisensor,leds_8bit;
u32 IsrStatus;
XGpio_Initialize(&clksensor,XPAR_CLK_LINEER_DEVICE_ID);
XGpio_Initialize(&sisensor,XPAR_SI_LINEER_DEVICE_ID);
XGpio_Initialize(&leds_8bit,XPAR_LEDS_DEVICE_ID);
XGpio_SetDataDirection(&leds_8bit,1,0x0);
XGpio_SetDataDirection(&clksensor,1,0x0);
XGpio_SetDataDirection(&sisensor,1,0x0);
Status = XDsAdc_Initialize(InstancePtr, DSADC_DEVICE_ID);
return XST_FAILURE;
while(1)
XGpio_DiscreteWrite(&leds_8bit,1,1);
SamplingDelay();
XGpio_DiscreteWrite(&leds_8bit,1,0);
// TSL1401_SI = 1; /* SI = 1 */
XGpio_DiscreteWrite(&sisensor,1,1);
SamplingDelay();
//TSL1401_CLK = 1; /* CLK = 1 */
XGpio_DiscreteWrite(&clksensor,1,1);
SamplingDelay();
//TSL1401_SI = 0; /* SI = 0 */
XGpio_DiscreteWrite(&sisensor,1,0);
SamplingDelay();
// TSL1401_CLK = 0; /* CLK = 0 */
XGpio_DiscreteWrite(&clksensor,1,0);
for(i=0; i<256; i++) {
SamplingDelay();
SamplingDelay();
SamplingDelay();
SamplingDelay();
//TSL1401_CLK = 0; /* CLK = 0 */
RxDataLength++;
SamplingDelay();
SamplingDelay();
// TSL1401_CLK = 1; /* CLK = 1 */
SamplingDelay();
SamplingDelay();
return 0;
void Delay(int delay)
int ii;
for( ii=0;ii<delay*10000;ii++);
My microblaze settings and c code are as below, but I can't receive any signals. Where am I doing wrong. thank you for your help.
02-22-2020 01:38 AM
