Visitor castillo.leo
Impact problem with AES-XLX-V5LX-EVL110-G
Hello
I have a problem
Checking cable driver.
Driver file xusb_emb.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
ESN device is not available for this cable.
INFO:iMPACT - Current time: 12/08/2015 13:26:25
Attribute TAP_SCAN_CLOCK is not found in Device 1 BSDL file.
Attribute TAP_SCAN_CLOCK is not found in Device 2 BSDL file.
Attribute TAP_SCAN_CLOCK is not found in Device 3 BSDL file.
INFO:iMPACT:477 - The bsdl for device 'UNKNOWN' is out of date. Please check your installation.
ERROR:iMPACT - Bsdl reader is not available for device 1.
The bsdl for device 'unknown' is out of date. Please check your installation.
INFO:iMPACT:477 - The bsdl for device 'unknown' is out of date. Please check your installation.
Can you help me?
Scholar austin
Re: Impact problem with AES-XLX-V5LX-EVL110-G
You should contact Avnet, as this is their board,
If anyone else has any experience with it, you may get an answer here, but Avnet should get back to you much faster,
Austin Lesea
Principal Engineer
Xilinx San Jose
thanks for your answer
