Observer shengfei
JTAG B Detached
Hi @anatoli
I'm not sure I should ask you or someone else, but the JTAG B interface on my KC705 is detached. How to handle it? I think I'm still in warranty.
Sincerely
Shengfei
Re: JTAG B Detached
Hello @shengfei ,
In this case, since you bought this directly from Xilinx, please log in to https://service.xilinx.com/sservice_prod/start.swe and under "RETURN", please open a new RMA related Service Request. Thanks and have a nice day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Re: JTAG B Detached
Hello @shengfei ,
As this is in relation to faulty/Detached micro USB port of the board, this is a mechanical defect and not electrical. Therefore, with mechanical defects, I can't really help you in this case.
You'd need to contact the authorised distributor who'd have purchased this kit from and if the board is still under warranty, indeed, they (e.g. Avnet, if this is who you obtain this kit from) can then submit an RMA Service Request for the board replacement.
If the kit isn't under warranty (i.e. >90 days since it was purchased from), Avnet would most likely advise you to contact Whizz systems to get this repaired at your own cost.
Whizz Systems are our contract manufacturer and official Xilinx Design Partner.
They are best placed to repair Xilinx Development Systems Products (Boards and Kits) at the cost of the customer.
Please use the following Whizz Systems contact:
Hope this helps.
Kind Regards,
Anatoli Curran,
Observer shengfei
Re: JTAG B Detached
Hi @anatoli
I bought this board directly from Xilinx website. Shall I still contact Avnet or someone else? I know it's beyond your responsibility, appreciate your help a lot.
Sincerely
Shengfei
Re: JTAG B Detached
Hello @shengfei ,
Kind Regards,
Anatoli Curran,
