JTAG Receptacle Replacement For ZC706 Development Board
Hi Community,
This sounds like a dumb question, but I have to ask if you guys know exactly what model I should buy in order to replace the JTAG receptacle on the ZC706 board ??
Because the piece fell off this board after so many plug and unplug cycles.
TH
Thanks vortex1601,
I have issued an order for JTAG-HS3 recently.
Thank you very much,
Have a nice day,
TH
The receptacle goes to a Digilent JTAG PMOD module. This is a sub-board mounted to the Xilinx board, so it's not so easy to replace.
Rather than replace the module, you can also use an external adapter, also from Digilent, and continue to use the board despite the broken connector. Their model JTAG-HS3 is suitable for this board.
See https://store.digilentinc.com/jtag-programmers-fpga-programming-solutions/
Thanks vortex1601,
Have a nice day,
TH
