KC705 ethernet
hi
I am using KC705 - kintex 7 board.
after powering ON the board  i connected the ethernet cable between the PC and Board.
but when i see the adapter setting in PC for ethernet it shows Network Cable unplugged
and no LED glows at  RJ45 of PC.
i tried using different twisted piar cable. cat5,cat6
but still its not working.
what is the solution for above problem??
Thanks and Regards
Re: KC705 ethernet
Hi gaonkar@123
Please check the below link which talks about how to fix network unplugged cable error in Windows :
https://www.drivereasy.com/knowledge/fix-network-cable-unplugged-errors-in-windows/
Check this in case of linux:
https://ubuntuforums.org/showthread.php?t=1709957
Rohit
Re: KC705 ethernet
hi gaonkar@123
can you run the BIST test which is provided in the below link , Built-In System Test (BIST) application uses an EDK MicroBlaze system to verify board functionality.  A UART based terminal program interface offers users a menu of tests to run and aslo in the same link we have the Ethernet example design to make user understand some of the base stuff related to Wireshark software.
https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#documentation
Let us know your inputs on the above information
Chandra
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Re: KC705 ethernet
Basically, test page allow you to test the ink level in your printer device. And, in what quality does your printer ink level can reach. It is a procedure of checking all the maintenance and troubleshooting problems.
