ML507 : Slave SelectMap/Serial problem
Hello everyone.
I try to download a bitstream stored in one xcf32p. I work for master serial, master SelectMap perfectly :). But when i want to download the configuration with slave modes, it doesn't work...
In Impact, I select the option for XCF32P to tell the memory is master, and i tried external and internal clocks without success.
Why I have this problem with Slave modes?
(I didn't precise that the mode pins are set correctly for the modes, i saw ML507 User guide)
I will read your answers after the week-end.
Thanks a lot for your help
Lamonnis
I had some problems with Impact and that's probabely the reason why this did not work. After reinstalling Impact it worked...
