fui860a
ML550 Virtex 5 Expansion Board
Hi, i'm just working on a ML550 Borad with Virtex 5 VLX50T.
I need to use ADC and DAC with 5-20 MHz bandwidth.
I'm thinking to use a LVDS expansion board but i don't know where i can found its.
Can you help me?
krishna11283
Please go through below link. You will find many expansion boards having ADC/DAC. All of these boards compliance to ML550. You can select as per your sampling rate.
http://www.xilinx.com/products/boards_kits/fmc.htm
fui860a
great work! I've seen these products.
I believe we will take this model:
http://www.hitechglobal.com/FMCModules/16-bit_AD-DA.htm
Now, my question is: how can i link this board to my ML550?
I've this kind of connectors (look pics) that are different from FMC standard.
lvds
mcgett
You cannot attach a FMC module to the ML550.  There are no FMC interfaces on a ML550.
fui860a
ok, so i can't connect any kind of expansion board on ML550!
can you help me to find a compatible board to link a DAC and ADC?
mcgett
To the best of my knowledge the only thing that uses these connectors on the ML550 are Samtec QSE cables for testing LVDS parallel transmit and receive interfaces.
