ML605 DDR3 maximum size
Hi all,
I have an ML605 in my disposal and I need to use it for an application that requires more than 512MB DRAM. In the documentation it is stated that 2GB is the maximum amount of memory supported. Has anyone tried using 4GB or 8GB DDR3 SODIMMs with the board? What are the technical issues (if any) for using 4/8GB dimms?
Thank you in advance!
