Not enough IO in SP605 what is a good upgrade?
Re: Not enough IO in SP605 what is a good upgrade?
Hi @computer110110 ,
Refer this link https://www.xilinx.com/products/boards-and-kits/see-all-evaluation-boards.html and please choose suitable board based your requirement(like number of IO, logic resources etc).
Hope this helps.
Deepak D N
Please reply or give kudo or Accept as a Solution.
Scholar u4223374
More information! What features of the SP605 do you need? What features of the SP605 don't you need? How many I/Os do you need? What are the requirements on those (speed, voltage, etc)? Does the new board have to be a Spartan 6 and/or work with ISE?
I am short 15 i/o ports TTL logic.
I need 15 I/O TTL ports. They will be used as outputs.
As @u4223374 asked, what are the speed and voltage requirements for your IO?  TTL (real 5V TTL) is a thing of the past.  Do you need 15 single ended ports or 15 more single ended ports?  That look like a pretty big connector on that board.
The same as the sp605. The same exact requirement that I am using on the sp605. There are 68 i/0 ports on the sp605. I need 15 more.
Hi computer 110110,
@u4223374 asked some very good questions to narrow your options.
If you want us to propose just one Eval Board, take a look at AC701:
https://www.xilinx.com/products/boards-and-kits/ek-a7-ac701-g.html
Andres
Thanks! I will look into this FPGA
