PCIe ML507 which GTX ?
I'm a bit confused about the location of the GTX transceiver for a PCIe 1x Lane on the ML507-Board.
In the ML507 data sheet the position is given as GTX_X0Y2.
But the ucf-files which where generated by the PCie Core Generator doesn't support this position.
Also Table 5-3 of ug341 (Supported Core Pinouts Virtex5 FXT) doesent't show such a position for a 1x Lane Configuration.
Is it critical whish receiver I use for my Pcie design.
Thank a lot for your support.
Kind regards
Friz
Re: PCIe ML507 which GTX ?
The PCIe lane is connect to MGT 118_0 on the FX70T-FF1136.  This translates to GTX_DUAL_X0Y2 as the physical site location.
If the CoreGen UCF file is incorrect, then you should change the location to match it the PCB implementation.
I am testing GTX pcie protocol over SATA  connector with loop back. Can you specify what changes you made to the origional project. The GTX core never synced up. I am resetting the core from outside.
You have responded to a thread that is more than five years old and does not appear to be related to your question.
Based on what I think your question is, you should open a new thread in the PCIe forum with the full details on the problem that you are having.
