PMOD AMP1 Troubleshooting
I've recently purchsaed the PMOD AMP1 module from digilent for use with my Nexys 2.
When I program the demo project (http://www.digilentinc.com/Data/Products/PMOD-AMP1/PmodAMP1_ISE_Demo.zip)
on the headphone output I can barely hear an extremely high pitch tone on the headphone out.
After reading through the source I realised this project is setup for a 100Mhz clock while my board is 50M. I modified the synth.vhd as below:
entity synth is
	port(clk : in std_logic;
		  syn_out : inout std_logic_vector(7 downto 0));
end synth;
architecture Behavioral of synth is
signal sclk : std_logic_vector(10 downto 0);
begin
	process(clk)
		begin
			if clk'event and clk = '1' then
			-- divide a clock by "10111010101" (1493) which is about the value of 100M/256/261.6
			-- where 100M is the clock frequency on a Nexys3
			-- 256 is the number of points in the sine wave table
			-- 261.6 is the frequency of a middle C
				if sclk = "1011101010" then -- MODIFIED decreased by half for 50Mhz clk (746 is new clock divider)
					--"11111111" is 255 is the maximum point in the sine wave table
					if syn_out < "11111111" then
						syn_out <= syn_out + 1;
					else
						syn_out <= "00000000";
					end if;
					sclk <= "00000000000";
				else
					sclk <= sclk + 1;
				end if;
			end if;
	end process;
end Behavioral;
 And re-programmed however this made absolutely no difference to the faint high pitched tone .
I've tried through speakers incase it was a gain issue, but to no avail. Also adjusting the pot on the PMOD itself.
Just wondering if anyone else has had any experience with this module/board combination?
Unfortunately I don't have access to an oscilliscope so can't see if the intermediate PWN signal is being correctly generated.
I also have the PMOD DA2 but thought I'd start with this as before jumping into the deep(er) end.
Lawrence
Re: PMOD AMP1 Troubleshooting
Probably worth mentioning I've also replaced the UCF file with the Nexys 2 one and uncommented the relevent nets (CLK, JA<3 - 0>
