Please reply me - 7-series GTX transceiver
Hello ,
please help in this regard.
I am working zynq family with part number xc7z045-2ffg900
actually I am trying to generate IP core 7-series GTx transceiver (chipscopr-ibert) for quad_111 and quad_112.I followed each and every  carefully step in  in the following pdf
XTP243 - ZC706 GTX IBERT Design Creation zc706-ibert-pdf-xtp243-14.5-c. .
got an  error message while generating the core
ERROR:sim - map failed on example_ibert_111_112.
ERROR:sim - Error found during generation.
is this problem with any kind of license?
please help me in this regard
regards
aditya
Re: Please reply me - 7-series GTX transceiver
It appears that you are following the instructions for ISE 14.5, but using ISE 14.4.   I would suggest that that you update the software to at least ISE 14.5 and preferably to ISE 14.7.
