Power Advantage Demo v1.00 on ZCU102 Rev 1.0(silicon version 3/4)
Hi experts,
I'm not sure what's the status for the following information:
# minicom -D /dev/ttyUSB3
!! Power Advantage Demo v1.00
!! Press ESC to enter System Controller mode.
Not like before there is a menu for PM-related, I can operate as the menu prompt.
"Press ESC" does  not work either, which means, no response any more.
There are two different status on /dev/ttyUSB0(Which suppose the output console for FSBL and u-boot)
On Silicon v3:
      There is no any output from /dev/ttyUSB0, which means it might be stuck in CSU bootrom.
      Question: Is there any way to get the board out of this stuck?
On Silicon v4:
      Normal output from /dev/ttyUSB0
      Question: Do I need to care the output from /dev/ttyUSB3?
Cheers, (Happy new coming year)
Zumeng
Re: Power Advantage Demo v1.00 on ZCU102 Rev 1.0(silicon version 3/4)
Hi zumeng.chen@windriver.com,
To use the power tool on ZCU102 rev1+ you need to use the ZCU102 SCUI tool. See AR#67308 for more information
Remember to close the UART terminal on this port to let the access to the tool.
Hope that helps,
Florent
Florent
Hope that helps,
Florent
Florent
Thanks ~, I'll take a look, anyway, feel free to close this case.
