startnexys3
Problem about write and read data from the psram on the Nexys3
Hi experts
I am a  newer in FPGA.Using the Nexys3 board to learn the abc. Recently i try to write a program to communicate with the PSRAM on the Nexys3.I find it is deadly hard to do that,no mater how i modify the code,it doesn't work.I add a UART to send the data to pc and found that  the data i read from the psram that i writed  are all ZERO  ??
Would you please tell me what's wrong with my code?
here are my code and the psram' s datasheet.
eteam00
Instructor
Instructor
Did you simulate your design to verify
  • correct reception by the UART
  • writing correct data to the correct psram address
  • reading correct address from the psram
  • sending correct data by the UART
  • resets and clocks working correctly
You mentioned that you added a UART to the design, but the base design should include a UART.
-- Bob Elkind
SIGNATURE:
Summary:
startnexys3
i count from 0 to 20 and write the number into the ram,then,the next 20 counts,i read from the ram.I have simulated and found that the address bus and timing seems have no question.so i generate the bit directly and program the spartan6.
       I have tested that uart work correctly, i think that the problem may lie in the communication with the ram.I also enable the led to show the data,but all the leds is off,when processing read.
       I read from the datasheet that it access time is both 70ns.so i use the state machine to read and write.i count from 0 to 9 ,when 1,i set the address , give data and pull down the cs and we, when 8, the write is finished.so i pull up the cs and we.read data is similar.
     sense that the nexys3's clk is 100mhz, the write and read time is meetted.so i really don't konw what's wrong.
eteam00
Instructor
Instructor
If you truly believe that you have done a thorough job of verifying your design with logic simulation, and your design does not function as simulated, then you have few options.  The first option is to verify with an oscilloscope (or ChipScope) that the hardware matches the simulation.
-- Bob Elkind
SIGNATURE:
Summary:
startnexys3
ok  i'll try a chipscope latter.
startnexys3
i try nearly one day to learn to use the chipscope and found that data writen is right, but read is all zero :-(
so i think that the timing must have problem,here is my simulation on writing screen shoot, can you see anyting wrong on it?timming.png
eteam00
Instructor
Instructor
Until you can correctly read the data which has been written, you do not know with certainty that the data is correctly written.
-- Bob Elkind
SIGNATURE:
Summary:
Anonymous
Not applicable
I recently created a Verilog module for the Nexys 3 which successfully does simple PSRAM reads and writes and should be reasonably easy to integrate into another design as long as you don't also need to use the flash chip that shares the same lines. I would be happy to share this with you, except I'm away from home (and my source code) until next Monday. Can you wait until then? FYI- there is a Verilog simulation model that you can use with ISim on the same Micron page as the datasheet, it'll tell you if you've violated important timing parameters or when you've read or written data successfully in the console area. This was extremely useful for me to get my own code working properly. Andy
startnexys3
:-)  while waitting for you, I try the FYI first.
startnexys3
:-(  It sense that Micron has stop to provide the FYI  up until now I can't find the simulate model.
Anonymous
Not applicable
The sim model is still there.  Go here: http://www.micron.com/parts/psram/cellularram/mt45w8mw16bgx-701-it?pc={BD8A72EA-2DC2-4B88-846E-7B59997A2D97} and click on the Sim Models tab about halfway down the page.
In any event, I'm home now, so in the next few minutes I'll look at packaging up my sample code for you.
Andy
Anonymous
Not applicable
OK, here's a ZIP containing a few goodies:
1) The AsyncPSRAM.v module which provides a simple interface to reading/writing the Nexys-3 PSRAM in async mode.  You may need to modify the number of waitstates in the state machine if you use an input clock frequency other than 100Mhz to this module.
2) A module which makes it easy to output values on the seven-segment display (in VHDL, everything else is in Verilog.)
Also note that the ISE archiver grabbed the module required for simulating the PSRAM but it claims it won't restore it to the right directory since it was external to the rest of the project.  You should just remove it from the project once you load it in ISE and then re-add it to the project whereever you wind up putting it, if you care about the simulation.
If you manage to successfully integrate this with your project, I will be interested to hear what was wrong with the code you tried to write, by comparison. (I would also be happy if someone else is succesful in making use of my code. :-) )
Andy
startnexys3
Thanks very much :-)   give me a little time to learn your code, it is quite helpful to me.
startnexys3
 :-) The problem is solved, How ridiculous! All the things about the timing are right. The key lies in Pin constraint. In the sch of nexys3 I found that the data0 of the Psram was connect to another chip the PIC Microcontroller, so I think it couldn't be used for the FPGA, the same is data1 and data 2.so I only connect to the psram with data3..15.
after I study the sch carefully I found that data0..2 was also connect to the fpga.So i add the three pins.And  the problem wad solved.All the leds are blinking happly :-)
Here comes my timing and code,maybe these would be helpful to newer of fpga.
write timing:
read:
By the way,I try to add the verilog psram to my code,but the xst can't Synthesis
it doesn't support real, and can't recognize the word ‘function’ :-(
Anonymous
Not applicable
Fyi, the XST verilog compiler supports the verilog "function" keyword just fne, in my experience. Anyway, glad you got your project working.
Anonymous
Not applicable
I don't know, if you already made it, but in your simulation, you have OE and WE active (= low) at the same time. For write cycles OE must be high. Otherwise you have a bus contention.
