bhavanithya
Problem with Hardware Co-Simulation for ZCU111 board
Hello Everyone,
I am trying to do hardware co-simulation (Simulink and ZCU111 Xilinx Board) using System Generator. When I select the board as "Zynq UltraScale+ ZCU111 Evaluation Platform Rev", the hardware co-simulation options for the compilation is disabled as seen in the below snapshot.
I observed for ZCU102 Zynq board it seems to be enabled only for JTAG,
Do anyone know what is the reason. Does ZCU111 board not support Hardware co-simulation ?
Any inputs are really appreciated. Thanks!
Additional Information:
Matlab Version:  2019.1
Vivado Version: 2019.1
System Generator version: 2019.1
Bhavanithya Thiraviaraja
Please Kudo or Accept as a solution, if this post helped you.
Tags (2)
andresb
Hi Bhavanithya,
This is our User Guide on Hardware Co-Simulation:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug897-vivado-sysgen-user.pdf
This Mathworks page has the list of boards supported:
https://www.mathworks.com/help/hdlverifier/gs/supported-eda-tools.html
Maybe this is a way of adding support for your board?:
https://www.mathworks.com/help/hdlverifier/ug/what-is-fpga-board-customization.html
Andres
bhavanithya
Hello Andre,
Thank you for your response. I checked the links, it seems that ZCU111 board is not available in the FPGA Board manager after installing HDL coder and HDL Verifier for Xilinx Zynq devices. I tried to create a custom board but my device xczu28dr-2-effvg1517 is not present under the category Zynq Ultrascale+.
Is it possible to add the board from file..but the board fle in the Vivado installation folder is not compatible with the format expect by the FPGA Board Manager in Simulink. I am using MATLAB 2019.1 and I am not sure why Simulink do not support ZCU111 board. Can you please give me some insights on how to proceed now?
