Anonymous
Not applicable
Running Single Carrier Spread Spectrum Tx on ML605 board with FMC-150 ADC/DAC daughter Card
I designed Single Carrier Spread Spectrum Transmitter in verilog. The behavioural Simulation of this design works perfectly.
I instantiated my design in the reference design project for FMC150 ADC/DAC card in order to chek my Loop back signal through ADC/DAC on chipscope pro. but the output of DAC using UDC is sine wave not my design signal. when i by pass UDC then output of dac is constan 23167. what is problem.
