Visitor sailorjerry
[SP-601] Can I use non differential clock on SMACLK_P pin?
I'd like to use external 10 MHz clock source instead of on board 27 MHz clock. The external clock I have is not differential though.
I just changed my UCF file from:
// ==== 27 MHz clock ====
NET "tcxo_clk_in" LOC = V10; # 27 MHz on board TCXO
TIMESPEC TS_tcxo_clk_in = PERIOD "tcxo_clk_in" 37.037 ns HIGH 50%;
to:
// ==== 10 MHz clock ====
NET "tcxo_clk_in" LOC = H17; # External 10 MHz clock
TIMESPEC TS_tcxo_clk_in = PERIOD "tcxo_clk_in" 100.000 ns HIGH 50%;
I also rerun clock wizard to make sure the same system clock as before  is generated.
Is there anything else I need to do?
Re: [SP-601] Can I use non differential clock on SMACLK_P pin?
There are comparators that produce an LVDS output.  You could use something like an ADCMP604 to turn your signal into an LVDS clock and use the port differentially, as it was originally designed.
You need to assign "tcxo_clk_in" a single ended IO standard.  Be sure the IO standard matches the signal that you are injecting.  Also, take a look at how the clock is terminated.
Also make sure the IO standard can be used with the VCCio on that bank that the clock is on.
Visitor sailorjerry
Thanks for a quick response. This is the waveform of my 10 MHz. What IO standard should I use?
Your signal is a sine wave centered around ground.  It goes significantly below 0V.  Unless the SMACLK_P port is AC coupled, you may damage the FPGA.  Is your scope set on 50 ohms input impedance or 1 Mohm?  It makes a difference as to what that signal will look like on your board.  How is the SMPCLK_P port terminated on the board?  That matters too.
In general, sine waves, especially relatively slow sine waves, aren't great for driving clocks.  Since you have a fairly gentle slope instead of a sharp edge, a small amount of noise on the signal translates into significant clock jitter.
It wouldn't surprise me that if the SMA port is AC coupled, that you might find an IO standard that works, but unless you are careful, you are risking the FPGA.  The safe thing to do is to build a circuit with a comparator to translate the sine wave into a logic signal.
Visitor sailorjerry
Thanks a lot, things are getting much clearer now.  Will use the comparator.
