SP701 evaluation kit - board_part definition was not found for xilinx.com:sp701:par0:1.0
Installed Vivado 2018.3.
Opened the project rdf0503-sp701-ipi-c-2018-3\sp701_ipi\sp701_ipi.xpr and get the following error.
I've ran the tcl command get_board_parts and can confirm that xilinx.com:sp701:part0:1.0 is missing.
How do I add the board_part definition?
Thanks for your help.
Re: SP701 evaluation kit - board_part definition was not found for xilinx.com:sp701:par0:1.0
Hi @ziltoid_the_omniscient ,
Yes this is the correct procedure to follow.
All recent boards for which you don't find board files in installation repository, you ought to download them from github and place them at same repository.
Ashish
I can see they are missing from the vivado board_files directory.
I copied the files from the github and it compiled. Is this the usual procedure to follow?
https://github.com/Xilinx/XilinxBoardStore/tree/master/boards/Xilinx/sp701/1.0
Ashish
Thank you @ashishd
