09-16-2019 05:50 AM
Hello there!
I'm working on Xilinx SPI IP Core, I'm unable to figure out how to handle tristate signals of IP core. I cannot use SDK and block design as I'm working with external slave SPI device. I can only play with the signals using VHDL/verilog coding.
Do I need to use a tristate buffer in VHDL code for these signals?
Please help me out. Thanks in advance!
09-20-2019 03:25 PM
Hello @sai_deepthi
I have attached links to forum questions that are very similar to the problem you are having.
I hope this helps, but if it does not, please let me know!
Forum2 (this link is also given in Forum1): https://forums.xilinx.com/t5/Embedded-Processor-System-Design/adc-3-pin-spi/td-p/687805
