patty_g
Spartan 3E Starter Board and LabVIEW FPGA
I would like to try to learn how to use LabVIEW FPGA on my Digilent Spartan 3E Starter Board.
I found this : http://www.slideshare.net/fpgabe/labview-fpga which makes me believe it is possible, but i have been unsuccessful in trying to get LabVIEW to detect my FPGA.
Please advise
claesvincent
yes it is possible to program an Xilinx Spartan3E starter board with LabVIEW FPGA.
actually this is my presentation.
You can find more information on this website:
http://pwo.fpga.be
more labs can be found here: http://pwo.fpga.be/LabVIEW/
Kind regards,
If you have any question don't hesitate to contact me.
The most possible problem you have is that you didn't install the LabVIEW FPGA Spartan3E driver for the board
https://lumen.ni.com/nicif/us/infolvfpgaxilsprtn/content.xhtml
jeyan
Please help me.
I have labview 8.5 and spartan 3e.
when i install  the driver from national instruments, it says ,it is to labview 8.6.
have you a driver to labview 8.5.
kosmos312
Hi, I am also looking at a problem to control Spartan 3E through labview, but I think I dun have any hardware from NI at this moment.
Is it still possible for me to use LABVIEW 8.5 to design program, and then change VI into VHDL and control Spartan 3E ?
THX
claesvincent
Contact your local NI representative for the driver for LabVIEW 8.5.They should help you.
It is not possible with the current LabVIEW versions to generate VHDL (however there is VHDL generated from your LV code but it is encrypted; you can't use it). You can run your VI on the Spartan 3E board without a problem check my labs under "course material" -> http://pwo.fpga.be
walid_farid
 Perhaps by now you found the Labview FPGA 8.5 driver that works with Spartan-3E. Anyway, here is the link from NI-site:
 http://forums.ni.com/ni/board/message?board.id=170&thread.id=340975
 Walid
Message Edited by walid_farid on 04-14-2009 12:51 PM
toppious
thnx. The site is very helpful. I have a question.
Spartan 3E driver is supported with labVIEW having academic license.And  I don't have a licensed version in my laptop. So after installing spartan 3E support for labVIEW 2009 also I am not getting spartan 3E starter board in new target or devices inside project explorer window. I have limited access to my university lab where the required license is there and I can deploy my vi to my spartan 3E.
  Is there any way to create and develop a project for spartan 3E in a pc without having the license ?
PLZ reply...
