01-20-2020 03:03 AM
Hi Team,
I am currently using the VCU118 evaluation board on which I wanted to have qspi flash model with the specification :
• Part number: MT25QU01GBB8ESF-0SIT (Micron)
• Supply voltage: 1.8V
• Datapath width: 8 bits
• Data rate: various depending on single/dual/quad mode.
With the reference to these specifications, I have got the related model from micron link as shown :
https://www.micron.com/products/nor-flash/serial-nor-flash/part-catalog/mt25qu01gbbb8esf-0sit
From Here I got the simulation model and data sheet.
I have query, Whether the downloaded model is compatible with the VCU118 board or Can you suggest the suitable model of QSPI flash memory for VCU118 board to be used ?
Waiting for the reply.
Prachi More.
01-21-2020 10:11 PM
Hi @gprachi123
Are you designing your custom board with reference to VCU118 hence you are looking for simulation models for qspi device on it?
Yes, downloaded model should be compatible with the VCU118 board. The specifications for third part components on our Eval boards are as per third party data sheet.
01-21-2020 10:11 PM
Hi @gprachi123
01-23-2020 02:33 AM
Hi Team,
Thanks for the quick response.
With this model I am able to do the page program operation with std SPI interface, but for DUAL and QUAD and qpi interface mode facing issues.
The page program is not able to complete while the read status register is going on and not able to complete, and expected is, it should give the rx fifo data as 03 which is read status register is in progress after completion of page program the rx fifo reg should give 00. So we can say device completed it's page progam operation and will go in IDLE state.
I can see the read dummy cycles provided in the data sheet is not exactly requied for read in different interface mode, is there any issue ?
Also, For page program operation it is taking much more time to complete arround 3 ms. can we reduce this time. ?
Erase operation is getting hang though the model understood the command. why it is so ?
Please provide the solution for those queries .
Prachi
