Ultra96 v2 failing to boot Edge-AI images
Dear Forum,
I have been able to use the Board image files for the ZCU102 and ZedBoard that are to be found on the AI developer Hub. https://www.xilinx.com/products/design-tools/ai-inference/ai-developer-hub.html#edge
However, both 2019 image files for the U96 board fail to boot, with zero led activity on the board as described in the quick-start guide (red INIT_B stays lit and blue DONE let never comes on). In addition there is no output from the serial port.
I know that the  board will boot ok, as I have also downloaded the Out-Of-Box image from the Avnet website, and this boots first time. Please note that I have been writing all image to the same uSD card using the same tools, so I don't think this is a HW issue.
I will download the U96 Edge AI images again in case they are both corrupt, but any help would be much appreciated.
I wonder if these images were built for U96-v1, where I have a v2 board.? Even so. I'd expect basic FSBL output prior to DDR failure.....
DJE666
Re: Ultra96 v2 failing to boot Edge-AI images
Looks like v1 vs. V2 bsp issue.🙁
