Using Chipscope Pro 10 with XtremeDSP Kit 4 ...
I wanted to know if I can use Chipscope Pro 10 with Xilinx XtremeDSP Kit 4, which is a PCI interface based FPGA kit. I know Chipscope Pro is a JTAG device based tool, but is it possible to use it for debugging using PCI interface or will I need to connect the JTAG cable to my PCI card if I want to use Chipscope?
Basically, if I want to use Chipscope Pro 10 with an XtremeDSP PCI interface card, will it work or no? Has anyone tried it before ... ?
Please do let me know ...
Z.
PS - I say Chipscorpe Pro 10 as I am using ISE 10.1
Re: Using Chipscope Pro 10 with XtremeDSP Kit 4 ...
PCI and JTAG are two different functions.  There will be no interaction issues.
ChipScope requires using a JTAG cable.
Thanks for your reply.
I know chipscope needs JTAG. I was wondering if I used both PCI and JTAG on the same board, will it be fine?
Since I need to debug the XtremeDSP kit, it needs to be connected via the PCI. So if I also connect the JTAG to it for chipscope, will that be fine or will that cause some conflict or result in the board burn up or something? Can JTAG and PCI be used like that together?
Do let me know ...
Z.
