Using ML605 in RGMII mode
I am using ML605(Vertex 6) board to send data from fpga to pc.I changed the jumpers to useit in RGMII mode. Do I need to do anything more like configuring IC using the code to make the board work in RGMII mode?
Scholar dpaul24
Re: Using ML605 in RGMII mode
@prasad_121601032,
If you are sending data at Gigabit rate, you would most probably  need to set the RGMII delays at the PHY chip.
Why don't you just try to send some packets from FPGA, capture it using Wireshark and analyze if it is broken or not.
FPGA enthusiast!
All PMs will be ignored
