gmoore
VC707 LCD Documentation
I wish to use the 16x2 LCD display panel on the Spartan VC707 board as part of a Verilog design project, but I cannot seem to find any documentation for the VC707 that explains the timing and control of the LCD .
The documentation for the Spartan-3E has a detailed section explaining the control commands and the timing for the LCD, but there doesn't seem to be an equivalent section for the Virtex 7 Vc707 board. I was working under the assumption that the timing and controls are the same for the VC707 as they are outlined for the 3E, but I am not sure. Can anyone confirm if the LCD section outlined here: http://www.xilinx.com/support/documentation/boards_and_kits/ug230.pdf remains valid for the VC707 ?
balkris
I think you can use the same code and port using this ARs
http://www.xilinx.com/support/answers/51139.html
you can find all the example design here
http://www.xilinx.com/products/boards-and-kits/ek-v7-vc707-g.html#documentation
Thanks and Regards
Balkrishan
gmoore
Hi Balkris,
Thanks for the links, I was working from the updated document version already so thankfully no issue with pins. Your answer would seem to suggest that the setup-times, wait times and all that are the same for the LCD in the 3E as in the VC707 ?
