Observer scott_wilson46
VGA input for ML506 (clock source)
I hope this is the right place to post this.  I am trying to get the VGA input working on my ML506 board.  I am assuming that the vga clock coming from theAD9980 is coming into the ML506 on pin AH18.  I have set up the iic interface with:
WHEN "0100" => SDA_BUFFER <= "1001100" & WRITE & ACK & "00000001" & ACK & "00110010" & ACK & STOP_BIT;
WHEN "0101" => SDA_BUFFER <= "1001100" & WRITE & ACK & "00000010" & ACK & "00000000" & ACK & STOP_BIT;
WHEN "0110" => SDA_BUFFER <= "1001100" & WRITE & ACK & "00000011" & ACK & "01001000" & ACK & STOP_BIT;
which should set up the AD9980 to work with 640x480 @ 50Hz.  I am then ANDing the HSOUT and VSOUT signals together to indicate to the FPGA that there is a pixel valid.  I expect there may be more synchronization I have to perform to make sure the beginning of a frame lines up but this should at least get something through my system.
My DVI output is blank which makes me suspect that there isn't a clock signal on the AH18 pin.
My code for getting pixels in is:
assign de = vsout & hsout;
always @(posedge vga_clk or posedge reset)
begin
if (reset)
begin
pixel_valid_out <= 1'b0;
r_out <= 8'd0;
g_out <= 8'd0;
b_out <= 8'd0;
end
else
begin
pixel_valid_out <= de;
r_out <= r_in;
g_out <= g_in;
b_out <= b_in;
end
end
Any ideas?
Best Regards,
Scott Wilson
Professor
Professor
Re: VGA input for ML506 (clock source)
That seems to be a pretty big leap to conclusions.  Have you tried to put a counter on the
vga_clk and run a bit to an LED to see if it is running?  I'd be much more likely to suspect
the framing signals if there is no DVI output.
-- Gabor
-- Gabor
I apologize for not answering back sooner.  I guess I should have been more explicit in my diagnosis of the issue.  I know that the vga_clk clock is not running because I attached a register to it that after reset would go high if the clock was there:
  if (reset)
     led_0 <= 1'b0;
  else
    led_0 <= 1'b1;
and the LED I have attached this signal to is always unlit.
Cheers,
Scott
Professor
Professor
I haven't looked at the ML506 schematics, so I may be wrong, but most boards drive
the LED cathodes low to light them.  So unless you have an inversion on led_0,
then always unlit means led_0 == 1 and the clock is running.  I commonly use a
counter to "see" a clock running like:
reg [24:0] vga_ctr = 0;
always @ (posedge vga_clk) vga_ctr <= vga_ctr + 1;
assign led_0 = vga_ctr[24];
If the LED blinks, you have a clock.  Normally if the counter sits at zero the LED is on steady.
-- Gabor
-- Gabor
