jahnavijanu.y
Vivado 2018.3
I had downloaded vivado 2018.3 how to get the license for this?
Thanks in advance
Jahnavi
ashok.cheepati
For getting the licence and features of different licencing options, you can go throgh the below mentioned user guide UG973.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug973-vivado-release-notes-install-license.pdf#namedDest=ObtainingAndManagingALicense
To go to the licence download page. In the vivado go to the help -> Manage licence -> obtail licence under set proxy.
Kindly accept as solution if the helpful.
GIve kudo
Best Regards,
--Ashok
ashok.cheepati
GIve kudo
Best Regards,
--Ashok
