vultureagle
VmodCam and Virtex 5 / Verilog
I am currently working on a project with a Virtex 5 FPGA and a VmodCam module .  The project is relatively simple: configure the FPGA-Vmodcam communication [i2c protocol], capture video and forward it to HDMI port [ I think that a TDMS video interface would fit ] . The "problem"  with the project is that I'm doing it in Verilog and I have to built it from scratch. The example provided by digilent is very vast and incredible hard to understand, especially that I am not very familiar with VHDL language. So it is very difficult for me to translate the code in verilog. I've designed the I2C protocol myself and now I want to load it into the board, but I am having troubles with the power up set up of the module.
Did anyone implement this project in verilog?
To be more specific the part I don't know how to deal with is this one:
	constant CLOCKFREQ : NATURAL := 24; --MHz
	constant TWI_MT9D112 : std_logic_vector(7 downto 1) := "0111100";
	constant RST_T1_CYCLES : NATURAL := 30; -- see MT9D112 datasheet
	constant RST_T4_CYCLES : NATURAL := 7000; -- see MT9D112 datasheet
	constant IRD : std_logic := '1'; -- init read
	constant IWR : std_logic := '0'; -- init write
	constant VMODCAM_RST_RISETIME : NATURAL := 25; --us
	constant VMODCAM_RST_RISETIME_CYCLES : NATURAL :=
		natural(ceil(real(VMODCAM_RST_RISETIME*CLOCKFREQ)));
	constant VMODCAM_VDD_FALLTIME : NATURAL := 100; --ms
	constant VMODCAM_VDD_FALLTIME_CYCLES : NATURAL :=
		natural(ceil(real(VMODCAM_VDD_FALLTIME*1_000*CLOCKFREQ)));
	constant VMODCAM_VDD_RISETIME : NATURAL := 50; --us
	constant VMODCAM_VDD_RISETIME_CYCLES : NATURAL :=
		natural(ceil(real(VMODCAM_VDD_RISETIME*CLOCKFREQ)));
	constant CMD_DELAY : NATURAL := 1; --ms
	constant CMD_DELAY_CYCLES : NATURAL :=
		natural(ceil(real(CMD_DELAY*1000*CLOCKFREQ)));
-- MT9D112 Reset logic
	RST_REG: process (CLK)
   begin
		if Rising_Edge(CLK) then
			if (SRst = '1') then
				RST_O <= '0'; -- reset MT9D112
				intRst <= '1'; -- reset this controller
				rstCnt <= 0;
			else
				if (rstCnt = RST_T1_CYCLES + VMODCAM_RST_RISETIME_CYCLES) then
					VDDEN_O <= '0'; -- after reset, we do a power cycle too
				elsif (rstCnt = RST_T1_CYCLES + VMODCAM_RST_RISETIME_CYCLES + VMODCAM_VDD_FALLTIME_CYCLES) then
					VDDEN_O <= '1'; -- turn on power
				elsif (rstCnt = RST_T1_CYCLES + VMODCAM_RST_RISETIME_CYCLES + VMODCAM_VDD_FALLTIME_CYCLES +
									 VMODCAM_VDD_RISETIME_CYCLES) then
					RST_O <= '1'; -- we can release the MT9D112
				elsif (rstCnt = RST_T1_CYCLES + RST_T4_CYCLES + 2*VMODCAM_RST_RISETIME_CYCLES +
									 VMODCAM_VDD_FALLTIME_CYCLES + VMODCAM_VDD_RISETIME_CYCLES) then
					intRst <= '0'; -- we can release this controller too
				end if;
				if (rstCnt < RST_T1_CYCLES + RST_T4_CYCLES + 2*VMODCAM_RST_RISETIME_CYCLES +
					rstCnt <= rstCnt + 1;
				end if;
			end if;
		end if;
   end process;
 I supose i can define the constants as parameters in Verilog but I don't know how to deal with functions such as
natural(ceil(real)))
vultureagle
Hi again,
I suppose I was a bit unclear in my post and that's why I didn't get a reply.
Now I'm trying to be more specific and hopefully I'll get an answer.
What I did so far in my attempt to translate vhdl to verilog is this:
1. I replaced the constants with parameters:
  constant RST_T1_CYCLES               : natural                      := 30;  -- see MT9D112 datasheet
  constant RST_T4_CYCLES               : natural                      := 7000;  -- see MT9D112 datasheet
  constant VMODCAM_RST_RISETIME        : natural                      := 50;  --us
  constant VMODCAM_RST_RISETIME_CYCLES : natural                      :=
  constant VMODCAM_VDD_FALLTIME        : natural := 200;  --ms
  constant VMODCAM_VDD_FALLTIME_CYCLES : natural :=
  constant VMODCAM_VDD_RISETIME        : natural := 100;  --us
  constant VMODCAM_VDD_RISETIME_CYCLES : natural :=
 With this:
 parameter 	RST_T1_CYCLES= 30;
 parameter	RST_T4_CYCLES= 7000;
 parameter VMODCAM_RST_RISETIME = 25; // us
 parameter VMODCAM_RST_RISETIME_CYCLES = 700; // Frecv clock * Risetime
 parameter VMODCAM_VDD_FALLTIME = 100; // ms
 parameter VMODCAM_VDD_FALLTIME_CYCLES= 2400000;
 parameter VMODCAM_VDD_RISETIME = 50; // us
 parameter VMODCAM_VDD_RISETIME_CYCLES= 1200 ;
 Now I am trying to translate this file:
entity LocalRst is
	 Generic ( RESET_PERIOD : natural := 4);
    Port ( RST_I : in  STD_LOGIC;
           CLK_I : in  STD_LOGIC;
           SRST_O : out  STD_LOGIC);
end LocalRst;
architecture Behavioral of LocalRst is
signal RstQ : std_logic_vector(RESET_PERIOD downto 0) := (others => '1');
begin
RstQ(0) <= '0';
RESET_LINE: for i in 1 to RESET_PERIOD generate
	process(CLK_I, RST_I)
	begin
		if (RST_I = '1') then
			RstQ(i) <= '1';
		elsif Rising_Edge(CLK_I) then
			RstQ(i) <= RstQ(i-1);
		end if;
	end process;
end generate;
SRST_O <= RstQ(RESET_PERIOD);
end Behavioral;
 And I have this :
module local_rst (clk, rsti, rsto);
	parameter rst_period= 5;
	input clk, rsti;
	output rsto;
reg [rst_period-1:0]  tmp_rst = {rst_period{1'b1}};
initial tmp_rst[0] = 1'b0;
generate
genvar i;
for (i=0; i<= (rst_period-1) ; i=i+1)
	begin: Generate
	always@ (posedge (clk), rsti)
		begin
		if (rsti ==1'b1)
		tmp_rst[i] <= 1'b1;
	else
		tmp_rst[i] <= tmp_rst[i-1];
	end
end
endgenerate
assign 	rsto = tmp_rst[rst_period];
endmodule
 But it works like this:
Can anyone tell me where did I do wrong?
Thank you.
vultureagle
I'm sorry, obviously the problem was here:
I was looking for tmp_rst[5] when MSB is tmp_rst[4].
I am very sorry about the multipost [and edit button would be great], but I still try to understand why it doesn't work like the original :
LE :  The for loop in verilog was set wrong. It was starting from 0 instead of 1.
I think I might be dealing with a race condition. I think that the initial block and the always block might pe executing in the same time.
I don't know how to correct the fact that tmp_rst[1] starts from 0 [the value of tmp_rst[0] ] because of this line :
	else
 I believe it has to do with the sensitive list .. it shouldn't evaluate this condition. So I decided to remove rsti from the sensitive list and now the simulation has the same result as in vhdl. But now if the reset is between clock fronts [even thought that 24 MHz clock should be enough ] it could miss it.
The final code is
	input clk, rsti;
	output rsto;
reg [rst_period-1:0]  tmp_rst = 5'b11111;
generate
genvar i;
for (i=1; i<= (rst_period-1) ; i=i+1)
	begin: Generate
	always@ (posedge clk)
		begin
		if (rsti ==1'b1)
		tmp_rst[i] <= 1'b1;
	else
	end
end
endgenerate
assign 	rsto = tmp_rst[rst_period-1];
endmodule
vultureagle
I have no idea why nobody is giving any sugestions, I guess I ask the wrong questions.
Anyway, I'm going to keep posting just in case someone is struggling with the same project.
From my last visit I've changed my FPGA board two times and now I'm working with an atlys [exactly like the one in the digilent demo]. The difference is that I have my own I2C FSM and protocol in verilog, very different from the one they have.  The problem is that with my implementation I don't  get an aknowledge. That s why I'm looking over their protocol and FSM and trying to figure out what I'm missing.
Here is the code that they have:
-- Company: Digilent Ro
-- Engineer: Elod Gyorgy
-- Create Date:    14:55:31 04/07/2011
-- Design Name:
-- Module Name:    TWIUtils - Package
-- Project Name:	 TWI Master Controller Reference Design
-- Target Devices:
-- Tool versions:
-- Description: This package provides enumeration types for TWI (Two-Wire
-- Interface) bus status and error conditions.
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
package TWIUtils is
  type busState_type is (busUnknown, busBusy, busFree);
  type error_type is (errArb, errNAck);
end TWIUtils;
package body TWIUtils is
end TWIUtils;
-- Design Name:
-- Module Name:    TWICtl - Behavioral
-- Target Devices:
-- Tool versions:
-- Description: TWICtl is a reusabled Master Controller implementation of the
-- TWI protocol. It uses 7-bit addressing and was tested in STANDARD I2C mode.
-- FAST mode should also be theoretically possible, although it has not been
-- tested. It adheres to arbitration rules, thus supporting multi-master TWI
-- buses. Slave-wait is also supported.
-- Dependencies: digilent.TWIUtils package	- TWICtl.vhd
-- Revision:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.math_real.all;
library digilent;
use digilent.TWIUtils.ALL;
entity TWICtl is
-- Title : Mode of operation
-- Description: The controller can be instructed to initiate/continue/stop a
-- data transfer using the strobe (STB_I, MSG_I) signals. Data flow management is
-- provided by the done (DONE_O) and error (ERR_O, ERRTYPE_O) signals. Output
-- signals are synchronous to CLK and input signals must also be synchronous to
-- CLK. Signals are active-high.
-- Fast-track instructions (single byte transfer):
--		-put the TWI address on A_I
--		-if data is written put it on D_I
--		-assert STB_I
--		-when DONE_O pulse arrives, read data is present on D_O, if any
--		-repeat, or deassert STB_I
-- Detailed data transfer flow:
--    -when DONE_O is low, the controller is ready to accept commands
--    -data transfer can be initiated by putting a TWI slave address on the A_I
--    bus and providing a strobe (STB_I)
--    -the direction of data transfer (read/write) is determined by the LSB of the
--    address (0-write, 1-read)
--		-in case of a 'write' the data byte should also be present on the D_I bus
--		prior to the arrival of the strobe (STB_I)
--    -once the data byte gets read/written, DONE_I pulses high for one CLK cycle
--		-in case of an error, ERR_O will pulse high together with DONE_I; ERR_O low
--		together with DONE_I high indicates success
--		-after DONE_I pulses high there is a 1/4 TWI period time frame when the next
--		strobe can be sent; this is useful, when multiple bytes are sent/received
--		in a single transfer packet; for ex. for write transfers, a new byte can
-- 	be put on the D_I and STB_I provided;
--		-if no new strobe is provided, the transfer will end
--		-if a new strobe is provided, but the address changed, the current transfer
--		will end and a new will begin
--		-starting a new transfer can be forced with the MSG_I pin; if asserted with
--		a strobe, the data byte will be written/read in a new packet; the advantage
--		of this is relevant only in multi-master buses: rather than waiting for the
--		current transfer to end and the bus to be released, a new transfer can be
--		initiated without giving up the control over the bus
	generic (CLOCKFREQ : natural := 50); -- input CLK frequency in MHz
	port (
		MSG_I : in STD_LOGIC; --new message
		STB_I : in STD_LOGIC; --strobe
		A_I : in  STD_LOGIC_VECTOR (7 downto 0); --address input bus
		D_I : in  STD_LOGIC_VECTOR (7 downto 0); --data input bus
		D_O : out  STD_LOGIC_VECTOR (7 downto 0); --data output bus
		DONE_O : out  STD_LOGIC; --done status signal
      ERR_O : out  STD_LOGIC; --error status
		ERRTYPE_O : out error_type; --error type
		CLK : in std_logic;
		SRST : in std_logic;
-- TWI bus signals
		SDA : inout std_logic; --TWI SDA
		SCL : inout std_logic --TWI SCL
end TWICtl;
architecture Behavioral of TWICtl is
	attribute fsm_encoding: string;
	constant FSCL : natural := 400_000; --in Hz SCL clock frequency
	constant TIMEOUT : natural := 10; --in ms TWI timeout for slave wait period
	constant TSCL_CYCLES : natural :=
		natural(ceil(real(CLOCKFREQ*1_000_000/FSCL)));
	constant TIMEOUT_CYCLES : natural :=
		natural(ceil(real(CLOCKFREQ*TIMEOUT*1_000)));
   type state_type is (stIdle, stStart, stRead, stWrite, stError, stStop,
		stSAck, stMAck, stMNAckStop, stMNAckStart, stStopError);
   signal state, nstate : state_type;
	attribute fsm_encoding of state: signal is "gray";
	signal dSda, ddSda, dScl, ddScl : std_logic;
	signal fStart, fStop : std_logic;
	signal busState : busState_type := busUnknown;
	signal errTypeR, errType : error_type;
   signal busFreeCnt, sclCnt : natural range TSCL_CYCLES downto 0 := TSCL_CYCLES;
	signal timeOutCnt : natural range TIMEOUT_CYCLES downto 0 := TIMEOUT_CYCLES;
	signal slaveWait, arbLost : std_logic;
	signal dataByte, loadByte, currAddr : std_logic_vector(7 downto 0); --shift register and parallel load
	signal rSda, rScl : std_logic := '1';
	signal subState : std_logic_vector(1 downto 0) := "00";
	signal latchData, latchAddr, iDone, iErr, iSda, iScl, shiftBit, dataBitOut, rwBit, addrNData &colon; std_logic;
	signal bitCount : natural range 0 to 7 := 7;
	signal int_Rst : std_logic := '0';
begin
--Bus State detection
SYNC_FFS: process(CLK)
   begin
			dSda <= SDA;
			ddSda <= dSda;
			dScl <= SCL;
      end if;
   end process;
	fStart <= dSCL and not dSda and ddSda; --if SCL high while SDA falling, start condition
	fStop <= dSCL and dSda and not ddSda; --if SCL high while SDA rising, stop condition
TWISTATE: process(CLK)
   begin
			if (int_Rst = '1') then
				busState <= busUnknown;
         elsif (fStart = '1') then --If START condition detected, bus is busy
            busState <= busBusy;
			elsif (busFreeCnt = 0) then --We counted down tBUF, so it must be free
            busState <= busFree;
         end if;
      end if;
   end process;
TBUF_CNT: process(CLK)
   begin
         if (dSCL = '0' or dSDA = '0' or int_Rst = '1') then
            busFreeCnt <= TSCL_CYCLES;
         elsif (dSCL = '1' and dSDA = '1') then
            busFreeCnt <= busFreeCnt - 1; --counting down 1 SCL period on free bus
         end if;
      end if;
   end process;
--Slave devices can insert wait states by keeping SCL low
   slaveWait <=   '1' when (dSCL = '0' and rScl = '1') else
                  '0';
--If the SDA line does not correspond to the transmitted data while the SCL line
--is at the HIGH level the master lost an arbitration to another master.
   arbLost <=     '1' when (dSCL = '1' and dSDA = '0' and rSda = '1') else
                  '0';
-- Internal reset signal
   RST_PROC: process (CLK)
   begin
         if (state = stIdle and SRST = '0') then
            int_Rst <= '0';
         elsif (SRST = '1') then
            int_Rst <= '1';
         end if;
      end if;
   end process;
-- SCL period counter
SCL_CNT: process (CLK)
	begin
			if (sclCnt = 0 or state = stIdle) then
				sclCnt <= TSCL_CYCLES/4;
			elsif (slaveWait = '0') then -- clock synchronization with other masters
				sclCnt <= sclCnt - 1;
			end if;
		end if;
	end process;
TIMEOUT_CNT: process (CLK)
	begin
			if (timeOutCnt = 0 or slaveWait = '0') then
				timeOutCnt <= TIMEOUT_CYCLES;
			elsif (slaveWait = '1') then -- count timeout on wait period inserted by slave
				timeOutCnt <= timeOutCnt - 1;
			end if;
		end if;
	end process;
-- Title: Data byte shift register
-- Description: Stores the byte to be written or the byte read depending on the
-- transfer direction.
DATABYTE_SHREG: process (CLK)
	begin
			if ((latchData = '1' or latchAddr = '1') and sclCnt = 0) then
				dataByte <= loadByte; --latch address/data
				bitCount <= 7;
				--set flag so that we now what is the byte we are sending
				if (latchData = '1') then
					addrNData <= '0';
				else
					addrNData <= '1';
				end if;
			elsif (shiftBit = '1' and sclCnt = 0) then
				dataByte <= dataByte(dataByte'high-1 downto 0) & dSDA;
				bitCount <= bitCount - 1;
			end if;
		end if;
	end process;
	loadByte <= A_I when latchAddr = '1' else
					D_I;
	dataBitOut <= dataByte(dataByte'high);
	D_O <= dataByte;
-- Title: Current address register
-- Description: Stores the TWI slave address
CURRADDR_REG: process (CLK)
	begin
			if (latchAddr = '1') then
				currAddr <= A_I; --latch address/data
			end if;
		end if;
	end process;
	rwBit <= currAddr(0);
-- Title: Substate counter
-- Description: Divides each state into 4, to respect the setup and hold times of
-- the TWI bus.
SUBSTATE_CNT: process (CLK)
   begin
			if (state = stIdle) then
				subState <= "00";
			elsif (sclCnt = 0) then
				subState <= subState + 1;
			end if;
		end if;
	end process;
SYNC_PROC: process (CLK)
   begin
         state <= nstate;
			rSda <= iSda;
         rScl <= iScl;
			DONE_O <= iDone;
			ERR_O <= iErr;
			errTypeR <= errType;
      end if;
   end process;
OUTPUT_DECODE: process (nstate, subState, state, errTypeR, dataByte(0),
	sclCnt, bitCount, rSda, rScl, dataBitOut, arbLost, dSda, addrNData)
   begin
		iSda <= rSda; --no change by default
		iScl <= rScl;
		iDone <= '0';
		iErr <= '0';
		errType <= errTypeR; --keep error type
		shiftBit <= '0';
		latchAddr <= '0';
		latchData <= '0';
		if (state = stStart) then
			case (subState) is
				when "00" =>
					iSda <= '1';
					--keep SCL
				when "01" =>
					iSda <= '1';
					iScl <= '1';
				when "10" =>
					iSda <= '0';
					iScl <= '1';
				when "11" =>
					iSda <= '0';
					iScl <= '0';
				when others =>
			end case;
		end if;
		if (state = stStop or state = stStopError) then
			case (subState) is
				when "00" =>
					iSda <= '0';
					--keep SCL
				when "01" =>
					iSda <= '0';
					iScl <= '1';
				when "10" =>
					iSda <= '1';
					iScl <= '1';
				when others =>
			end case;
		end if;
		if (state = stRead or state = stSAck) then
			case (subState) is
				when "00" =>
					iSda <= '1'; --this will be 'Z' on SDA
					--keep SCL
				when "01" =>
					--keep SDA
					iScl <= '1';
				when "10" =>
					--keep SDA
					iScl <= '1';
				when "11" =>
					--keep SDA
					iScl <= '0';
				when others =>
			end case;
		end if;
		if (state = stWrite) then
			case (subState) is
				when "00" =>
					iSda <= dataBitOut;
					--keep SCL
				when "01" =>
					--keep SDA
					iScl <= '1';
				when "10" =>
					--keep SDA
					iScl <= '1';
				when "11" =>
					--keep SDA
					iScl <= '0';
				when others =>
			end case;
		end if;
		if (state = stMAck) then
			case (subState) is
				when "00" =>
					iSda <= '0'; -- acknowledge by writing 0
					--keep SCL
				when "01" =>
					--keep SDA
					iScl <= '1';
				when "10" =>
					--keep SDA
					iScl <= '1';
				when "11" =>
					--keep SDA
					iScl <= '0';
				when others =>
			end case;
		end if;
		if (state = stMNAckStop or state = stMNAckStart) then
			case (subState) is
				when "00" =>
					iSda <= '1'; -- not acknowledge by writing 1
					--keep SCL
				when "01" =>
					--keep SDA
					iScl <= '1';
				when "10" =>
					--keep SDA
					iScl <= '1';
				when "11" =>
					--keep SDA
					iScl <= '0';
				when others =>
			end case;
		end if;
		if (state = stSAck and sclCnt = 0 and subState = "01") then
			if (dSda = '1') then
				iDone <= '1';
				iErr <= '1'; --not acknowledged
				errType <= errNAck;
			elsif (addrNData = '0') then
				--we are done only when the data is sent too after the address
				iDone <= '1';
			end if;
		end if;
		if (state = stRead and subState = "01" and sclCnt = 0 and bitCount = 0) then
			iDone <= '1'; --read done
		end if;
		if (state = stWrite and arbLost = '1') then
			iDone <= '1'; --write done
			iErr <= '1'; --we lost the arbitration
			errType <= errArb;
		end if;
		if ((state = stWrite and sclCnt = 0 and subState = "11") or --shift at end of bit
			((state = stSAck or state = stRead) and subState = "01")) then --read in middle of bit
			shiftBit <= '1';
		end if;
			latchAddr <= '1';
		end if;
		if (state = stSAck and subState = "11") then --get the data byte for the next write
			latchData <= '1';
		end if;
	end process;
NEXT_STATE_DECODE: process (state, busState, slaveWait, arbLost, STB_I, MSG_I,
SRST, subState, bitCount, int_Rst, dataByte, A_I, currAddr, rwBit, sclCnt, addrNData)
   begin
      nstate <= state;  --default is to stay in current state
      case (state) is
         when stIdle =>
            if (STB_I = '1' and busState = busFree and SRST = '0') then
               nstate <= stStart;
            end if;
         when stStart =>
            if (subState = "11" and sclCnt = 0) then
					nstate <= stWrite;
				end if;
			when stWrite =>
				if (arbLost = '1') then
					nstate <= stIdle;
				elsif (subState = "11" and sclCnt = 0 and bitCount = 0) then
					nstate <= stSAck;
				end if;
			when stSAck =>
					if (int_Rst = '1' or dataByte(0) = '1') then
						nstate <= stStop;
					else
						if (addrNData = '1') then --if we have just sent the address, tx/rx the data too
							if (rwBit = '1') then
								nstate <= stRead;
							else
								nstate <= stWrite;
							end if;
						elsif (STB_I = '1') then
							if (MSG_I = '1' or currAddr /= A_I) then
								nstate <= stStart;
							else
									nstate <= stRead;
								else
									nstate <= stWrite;
								end if;
							end if;
						else
							nstate <= stStop;
						end if;
					end if;
				end if;
         when stStop =>
				if (subState = "10" and sclCnt = 0) then
					nstate <= stIdle;
				end if;
			when stRead =>
				if (subState = "11" and sclCnt = 0 and bitCount = 7) then --bitCount will underflow
					if (int_Rst = '0' and STB_I = '1') then
							nstate <= stMNAckStart;
						else
							nstate <= stMAck;
						end if;
					else
						nstate <= stMNAckStop;
					end if;
				end if;
			when stMAck =>
					nstate <= stRead;
				end if;
			when stMNAckStart =>
					nstate <= stIdle; -- arbitration lost, back off, no error because we got all the data
				elsif (subState = "11" and sclCnt = 0) then
					nstate <= stStart;
				end if;
			when stMNAckStop =>
					nstate <= stStop;
				end if;
         when others =>
            nstate <= stIdle;
      end case;
   end process;
-- Open-drain outputs for bi-directional SDA and SCL
   SDA <= 'Z' when rSDA = '1' else
          '0';
   SCL <= 'Z' when rSCL = '1' else
          '0';
end Behavioral;
 My problem is with this part:
	begin
			end if;
		end if;
	end process;
 Why are they calculating timeOutCnt if they dont use it anywhere in the rest of the code. What is the effect of this process?
