XPM_MEMORY_DPDISTRAM
Hi, I'm currently working on a university project to build a 16-bit CPU that is supposed to run on the Basys3 board, which requires the use of the dual-port distributed RAM macro XPM_MEMORY_DPDISTRAM to implement a 1024 byte RAM module. I was instructed to read the UltraScale Architecture Libraries Guide, and so far, I know where this XPM template is. What I don't know is "copy the contents of the template and paste into your source file." I'm not an expert in VHDL so please kindly teach or show me how to include this template in my design. Thank you!
@williamntv
In VHDL, we often declare and instantiate a VHDL component inside another VHDL component.   Using a Xilinx XPM macro is similar.  That is, you instantiate the macro but you do not declare it.
You can try highlighting the instantiation template for XPM_MEMORY_DPDISTRAM found in UG974 and then do a copy-paste into the text-screen of Vivado where you are writing your VHDL.
However, a better way is to use the Vivado Language Templates as shown below - and do a copy-paste into the text-screen of Vivado where you are writing your VHDL.
Finally, be sure include the xpm library as shown below at the top of your VHDL file where the XPM macro is instantiated.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library xpm; use xpm.vcomponents.all;
Mark
@williamntv
library IEEE;
Mark
Thank you for your instruction. Really appreciate that you have shown me the how-to. Have a great day!
