ronnie2
Xilinx DLC-9LP usb programmer
Hi. I have DLC-9LPMC Programmer and I'm going to buy ZYNQ7020 Z-Turn board. Can I use this Xilinx programmer with Z-Turn board?
hpoetzl
Hey @ronnie2
If I'm not mistaken, the DLC9LP features the 14pin 2mm pitch JTAG connector while the MYiR Z-turn board has a 14pin 2.54mm pitch JTAG connector.
The DLC9LP seems to be still supported by recent Vivado.
So all you probably need is an adapter from 2mm to 2.54mm (which might have come with the DLC9LP).
Hope that helps,
Herbert
hpoetzl
Hey @ronnie2
Hope that helps,
Herbert
ronnie2
Thanks for your reply. Big help
hpoetzl
You're welcome!
austin
Did you ask:
http://www.myirtech.com/list.asp?id=502
Austin Lesea
Principal Engineer
Xilinx San Jose
ronnie2
I want to buy the board from an Iranian distributor, but  I'll ask. Thanks.
