Visitor gabriellobao
XtremeDSP Kit for Virtex-4 - CLOCK
Hi everyone!
I'm using a Nallatech Xtreme DSP Kit with a Virtex-4, and I need to feed the ADCs and the DCAs with the DIME clock_A, to achieve total clock control on ADCs/DACs.
But there is no ready to use precompiled bit file to the clock FPGA (like osc_clock_2v80.bit).
Does anybody knows how can I do it? How can I generate a bit file the drive the clock_A to the ADCs?
Thanks!
Historian
Historian
Re: XtremeDSP Kit for Virtex-4 - CLOCK
@gabriellobao wrote:
Hi everyone!
Without knowing anything about this board, I'll assume that it has an onboard clock source for the FPGA, and all you really need to do is to forward it out the correct pin to the ADC.
Yes! That's the point!
I really just need to forward it out, but I have no access to the clock FPGA (it's a Spartan-II VC2V80) I didn't create a project to assign the correct pins, I just load the FPGA with a ready-to-use bit file that's provided by Xilinx.
If I could edit this code, sure I would assign the correct pins, but I can't.
That's my problem...
