volkerluecken
ZC702 BIST Failure
I ordered three ZC702 (Rev 1.0) evaluation boards, which I'm trying to set up now.
The first board worked flawlessly with the BIST (SW16 = 00010) and the embedded Linux on the SD card supplied (SW16 = 00110).
With both other boards, I am unable to set up a communication (here with TeraTerm) in the BIST. The BIST binary counter on the DS15-DS22 LED chain is running fine, but neither the main menu nor anything else are showing up in the (correctly configured, as Board 1 is working) terminal.
When, on the other hand, trying to boot the other boards from the SD card, I get the following messages on the terminal:
Board 2:
Xilinx First Stage Boot Loader
Release 14.3 Oct 4 2012-17:59:57
Silicon Version 1.0
Boot mode is SD
Bitstream Download Start
Silicon Version 1.0
WDT_RESET_OCCURED
Boot mode is SD
Board 3:
Silicon Version 1.0
DDR_INIT_FAIL
FSBLStatus = 0xA009
Troubleshooting steps so far:
- All jumper / switch settings have been compared to the functional board and the ZC702 Checklist Documentation.
- Flashing Quad SPI ("Restoring flash contents...")
What else could possibly cause these issues?
Thanks in advance.
amandaw
Please refer to the ZC702 Board Debug Checklist, which is a part of the larger Boards & Kits solution center to ensure that your board is in good working order.
