11-30-2016 11:57 PM
I am running a project on zynq ZC702. The DS4 Led on my board is off, I have already check the Zynq Configuration on https://www.xilinx.com/support/answers/54012.html and I have already reprogramming the Board with an USB Interface Adaptater but the DS4 led is still off.
Do you know what is the reason of this cause ? and How can I resolve this problem ?
Vinod
12-01-2016 04:24 AM
12-01-2016 04:42 AM
I already follow this AR but the DS4 led is still off.
Do you have an other solution?
Vinod
12-01-2016 04:57 AM
12-01-2016 05:02 AM - edited 12-01-2016 05:03 AM
@vinod_dass DS4 low indicates the PowerGood of DDR3 VTT regulator is pulling it Low. Can you try probing the voltage on VTTVREF_PS rail & VTTDDR_PS rail?
12-01-2016 05:31 AM
When I use the USB Interface Adapter, I have this :
Can you explain me what these errors means, please ?
12-01-2016 05:34 AM
I can't connect my ZC702 on my CPU.
I don't think we have the warranty for this card
Vinod
12-01-2016 05:36 AM
@vinod_dass Those errors are clear indication of the Power regulator being out of regulation. Instead of 2.5V, it is only 0.27V
Try reprogramming the Power Controller following this
https://www.xilinx.com/Attachment/ZC702_Power_Controllers_Reprogramming_Steps.pdf
12-01-2016 05:49 AM
I already reprogramming my ZC702 with USB Interface Adapter but the DS4 led is at the same status : "off".
Vinod
12-01-2016 05:56 AM
Oops. Not a good sign then. Points to there being some kind of a short or device damage that is getting the voltage rail to completely go off spec.
Since you don't have warranty, your option is to try debugging the board for the short that is causing the voltage drop.
12-01-2016 06:04 AM
Yes but i don't know how to debug the board. I don't find the solution.
Is there a way to send the board for repair to Xilinx support ?
Vinod
12-01-2016 06:08 AM
Whizz Systems are the contract manufacturer for the Eval Boards. They would be best placed to repair the board at your cost.
Check with them .Their contact details at http://www.whizzsystems.com/contacts.html
12-01-2016 06:13 AM
Thank you,
Do you have a solution to repair this board myself ?
Vinod
12-22-2016 06:12 AM
No one has an other idea for repair my board ?
12-22-2016 11:32 AM
@vinod_dass Board repair / debug is something that takes a while to learn and fix the issue. Since the regulator is the cause of the issue, try looking at the schematics for that supply and check for shorts or any burnt out components in its path.
