ZC706 BIST test fails to connect
I am using ZC706 board(brand new, just out of the box). I have installed all the required software and the Switch positions are correct.I have gone through the comments given in this portal and checked the configurations, all seems to be correct.
SW4: 01(digilant), sw11 : 00010 ( Boot fromQSPI), Installed the 2015.4 version of XILINX SDK and Vivado
but when I am using the command prompt, to run the BIST test , i am getting the following errors.
C:\zc706_bist\ready_for_download>call C:\Xilinx\SDK\2015.4\bin\xmd.bat -tcl download_bit.tcl system_wrapper.bit
****** Xilinx Microprocessor Debugger (XMD) Engine
****** XMD v2015.4 (64-bit)
**** SW Build 1412921 on Wed Nov 18 09:43:45 MST 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
Executing user script : download_elf.tcl
JTAG chain configuration
Device ID Code      IR Length Part Name
1          23731093     6              xc7z045
Error Executing User Script : download_elf.tcl
Error :: ERROR:
Could not find a ARM device on the board. Please check if the target is in:
1. Split JTAG mode - No operations are possible with ARM DAP
2. Non Jtag bootmode - Bootrom may need time to enable DAP. Please try again
I am using the Window10 environment and the device driver for usb looks ok
USB-Driver.pngCan someone help me to resolve this issue on  ZC706 board ?
I am able to connect now.
Readsons for not connecting
1. USB driver in windows
2. SD card shipped with the board was corrupted(Not readable, boot sector fault). Need to rebuild the image in another SD card.
Regi
Hello @rgeorge
Try following steps:
1. First uninstall exisitng version of silabs drivers from your windows 10 machine.
2. Install v6.7 of USB to UART drivers.
3. Restart the machine.
4. Try the BIST design again.
Above steps should help fix your issue.
Kunal
Hello @rgeorge ,
This topic is still open and is waiting for you.
If your issue is not solved yet, please reply in the thread, so that we can assist you with your issue.
However, if your question is answered and/or your issue is solved, please mark the response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.  We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Regi
@rgeorge
Can you mark the appropriate post as accepted solution to help the community?
Kunal
